I am having problems connecting to the internet...i get a pci error
    Problem Solver:
  • 5 Answers
On and off all the device
Posted on Oct 11, 2010
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
KV8-X motherboard. I have a network card installed, but I keep getting new hardware found for ethernet. I try to disable the ethernet card via system. I can't connect to internet.
If you are trying to connect through a modem/router you it should have come with a disk then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
Apr 26, 2011 | AMD ASUS K8V-X (MBASUSK8VX) Motherboard
I have Acer Aspire ast180-es340m desktop. I had
Install the mainboard drivers, if you have a recovery partition use that.
Try system restore if you know the system is clean.
Other things to try a system file checker.
PCI has Plug and Play does it relate to your network card? Or modem?
remove it and reseat it.
In xp >start button> windows help n support> select fixing a problem networking> run automated diagnoses
Jan 21, 2010 | Computers & Internet
It gives me error when i setup tuner
Upon installing your Philips SAA7130 TV tuner/Fm radio/ Video PCI Capture Card. You can switch your PC on, and get connected to the internet without opening any window. Left click the Control Panel, and the Add hardware wizard. Then follow the instruction. You will be prompted to load your CD installer software driver, if the PC cannot find any driver soft-
ware in the O.S., In case you don't have a CD, your
PC will look it by itself at the internet since you are already connected, just follow and wait to get it installed. Hope this helps.
Dec 12, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
Can't connect internet. message reads error 633,
Here is a tip to work normally your modem, transfer it to another PCI Slots in the Motherboard and install again with the driver freeware provided. See to it that no other programs run on the system that interrupt your modem installation and diagnose it.
Please rate me.
Thank you.
Sep 15, 2009 | HP BCM5705 Modem
Alcatel Speed Touch PCI Modem doesn't work on my Win 98
Windows 98 0r 98se are no longer supported by any kind of internet service providers anymore only windows 2000 and newer. hope this helps.
Aug 10, 2009 | Alcatel Speed Touch Modem
Sharing internet from dlink 510g to linksys wap54g AP
yes, the manufacturer doesn't really matter as long as they are 802.11g (usually backwards compatible with a and b) so as long as the router and the adapters are installed properly NO problem
May 14, 2009 | D-Link High-Speed 802.11g Wireless PCI...
Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
