Question about Hitachi 50UX58B 50" Rear Projection Television
There is a yellow gost image, otherwise the tv seems to work normally.
  • Hitachi Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
There is a yellow gost - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
Sony BRAVIA KLV-37U300A 37 In LCD TV with shadow background on screen
That sounds like a defective LCD panel tab, Sony's and Samsungs are notorious for this problem. Does the problem go away when the set warms up or when you tap the screen?
Dec 07, 2012 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Westinghouse led tv has gost images
Look for any loose contacts in RC jacks/sockets/Cable. Try changing the input device to something you are sure, works such as a DVD player.
Aug 06, 2012 | Westinghouse LTV-20V2SL 20.1 in. ED-Ready...
I purchased a 32" Dynex
You only need to plug in the Red/White/Yellow plugs. Make sure you plug them into the correct colors on the TV. Most HDTVs have Red/Green/Blue ports. DO NOT use these ones, they are for receiving HD video signals. A lot of HDTVs also have the Red/White/Yellow plugs on the side of the TV (often labeled "Game", maybe something like "Video 3")
The Red/White/Yellow cables are known as RCA cables or Composite cables so look for any ports with those labels as well.
May 09, 2011 | Nintendo Super NES Console
My son has turned on his x box which seems to show the normal green light but cannot see anything on any of the tv's in the house. This worked yesterday but I put it in the cuboard last night and now it...
check the video cable that hooks to the xbox... it has a switch for normal tv and hd tv.....and also try a different input on the tv... but first check to make the cable is hooked to the tv correctly...red 2 red, yellow 2 yellow , and white 2 white.....if all of that ok then xbox quite...
Feb 04, 2011 | Microsoft Xbox 360 Console
Gosting image
Hello
Ghost image, otherwise called multiple images, that seen as duplicate one next to the picture, normally left side, are mainly due to the reflections of TV signals. That is two signals of the same object, but different in amplitude and in direction comes to the antena of the TV. Both of them gets processed by the internal circuits of the telivison, and comes as images on the screen. The first strong signal will produce strong image, and following will get to the next of it. Due to, say if a news reader appears on the screen will have a shade of the image very next to it, which is annoying.
The only remedy is to prevent the reflected image that comes to the antenna. Tv signals are transmitted in a techniqe called Horizontal Polarisation. That is, signals send from the transmitting tower comes to your antenna, in such a way that to a snake travels on a plane land. On the way if there is an obstruction, it will be delayed, if there is any high rise bulilding or so behind the way of its path that is some distance far away from your antenna or just behind the antenna and transmitter, that high rise structure will reflect the transmitted waves back to your antenna, which causes Ghost image to be produced.
You just reorient your antenna in suach a way that there will be no reflection signals comes to it, and the orginal transmitted signal from the tower only reach to it. You may have to repoition it or have to hoist higher or so. It is a trial and error method, while watching picture on your TV.
I advice you so, thinking that nobody has realigned the video If stage circutary inside your TV. If anybody has done so without proper testing and aligning equipment, this fault may occur. OK.
Nov 05, 2010 | Sony Televison & Video
My samsung 47 in projrction tv has blue gosting or a blue double
Thats usually related to the convergence Ics and the 3.9 ohm resistors needing replacement.
Jan 23, 2010 | Samsung HC-P4752W 47" Rear Projection...
Infocus X2 projector
resolution changes. if you hit auto image, that should correct it.
Sep 03, 2009 | Compaq MP2800 Microportable Projector sps...
Lamp light is steady yellow. TV works fine otherwise.
Order another lamp and have it on standby as the steady yellow light is telling you that the lamp has outlasted the normal rated useage hours so your lamp will fail without warning at any time.
May 13, 2008 | Mitsubishi WD-52628 52" Projection HDTV
VS-4543 Mitsubishi 45" TV
Replace red convergence IC,both IC's for solid fix
Jan 12, 2008 | Mitsubishi VS-4543 45" TV
Televison & Video Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
