Question about Roper RTW4300SQ Top Load Washer
3 year old Roper top load washing machine will fill with water but the timer does not advance and it does not begin any type of cycle. I checked the lid switch both physically and with an ohmmeter and it checks out just fine. When I pull the timer knob it will begin to fill with water but will not do anything past that. I'm assuming my next step is to test the timer, but how do I do this? There are quite a few different wires and connections behind it, and I don't want to start taking it apart before I have at least some idea as to what I am doing. Thanks!
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 146 Answers
Check the lid-closed switch. Once filled with water, most machines will not agitate or spin unless the lid is closed.
Posted on Apr 28, 2017
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Posted on Apr 12, 2008
  • 1073 Answers
SOURCE: Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Posted on Apr 20, 2008
vickygomar
  • 460 Answers
SOURCE: i am trying to get access to the top front of
this video will help you how to remove your top front washer mishine.
http://www.youtube.com/watch?v=vogysB7XOc8
Thank you
Yourratting is very important for me
Was this helpful?
Posted on May 21, 2009
  • 72 Answers
SOURCE: Roper top load washing machine. Fills with water and then stops
Check out the drain pump, it is not uncommon stuff gets stuck in the impeller preventing it to do its work.
Also check out the drain filter and that the drain tube is not clogged. Very common causes of trouble in my experience and would give symptoms like you describe..
A good method to check if the output side is clear may seem a little gross but... take a deep breath and blow through the drain tube from the other end (taking whatever precautions you feel like).... It should be possible and if you can't, you know where the problem is.
  • 530 Answers
SOURCE: washer fills up but wont switch to agitate
posibble bad timer. if it is skipping over the agitate.
Posted on Jun 15, 2009
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer will not cycle
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    The washing machinge is not completing the complete cycle
    Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
    Hi there. I can help you.
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
    Jun 18, 2009 | GE WSXH208A Front Load Washer
    Washer fills up but wont switch to agitate
    Jun 15, 2009 | Roper RAS8445KQ Top Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Slow to fill
    wher e the washing machine hoses connect alot of times there is a little screen to catch particulate in water try cleaning it
    Feb 06, 2009 | Roper RAS6233KQ Top Load Washer
    Simpson enduro 701 very slow to fill and timer sticks
    Hi my name is joyce, sounds like you have trash in you water filter that is in your water line that comes in your machine in the back of washer, this may be the cause for the slow water and the timer will cause the machine not to advance to the next cycle, if you would like I will help to find a service techincian.
    Joyce
    Washer will wash but will not advance after draining wash
    Very likely a dead spot in the timer, but check the lid switch (bypass it is best) to make sure it in not working intermittently. Hope this helps!
    Jan 29, 2009 | Roper RAS8445KQ Top Load Washer
    Roper RTW4300SQ Top Load Washer Logo
    55 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
