Question about Welding Tools
The tip light on my Miller Spectrum 500 plasma cutter stays on which will not let the machine operate.
4 Suggested Answers
SOURCE: can i plug my miller spectrum 1000 plasma cutter
no you idiot! the plug is different & even if you could somehow, its half the power output. Your plasma welders for the matter, have whats called a duty cycle, which plays into effect.... electrical load level....ect.
HOWEVER-- you can plg ito the same outlet as your stove, washer & dryer plugs. DON'T BURN YOUR HOUSE DOWN, The wife will kill you!
Posted on Sep 05, 2010
SOURCE: how much does a circuit board cost for a miller
depend the circuit boar but is be twin 500 and 700 usd
Posted on Feb 08, 2011
  • 5 Answers
SOURCE: miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Posted on Nov 27, 2011
Miller spectrum 500 plasma cutter problem with air/ gas light.
hi thee could you explain the problem further?
kolbrun
Apr 22, 2012 | Miller Welding Tools
Miller 375 x-treme fires about 30 seconds then stops it doesn't stay running, no trouble lights...
Have you watched to see if the pressure light comes on right before shutdown? If so you may need to add a tank right next to the torch base to address the pressure drop assuming your air source is able to deliver adequate volume to the cutter continuously and you currently have more than 25 feet of hose between cutter and compressor. It might not hurt to check the internal filter as well.
Dec 29, 2011 | Miller Spectrum 375 X Treme Plasma Cutter...
Miller plasma cutter spectrum 625
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Im looking for a miller spectrum 1251, where can i find one?
I have a miller spectrum 1251 for sale. We moved to a different shop that doesn't have three phase, but the machine has only been used a couple of times. You can reach me at 660-229-0171 if you are interested.
Sep 17, 2010 | Miller SPECTRUM 1251 907305-01-1 PLASMA...
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Spectrum 2050 plasma cutter will not arc
Possible failure of the trigger switch and or the cable back to the unit. Use an ophmmeter to check that the trigger and cable are good,
Then with the ohmmeter check the continuityu of the cable to the electrodes,
Connectors are always suspect.
These are starting ponts to check.
Mar 04, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
I can cut for about 4 min. then Cup Error
look at your duty cycle 40 % duty cycle is 4 min 10 min sraight is minimum 100%, but good machines weld for 3 or 4 shifts till they get turned off
my 2 cents
Feb 25, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I bought a used miller spectrum 625, can put on
The consumables on the torch head could be incorrect or not installed correctly. check these.
Sep 28, 2009 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Cup light is on machine will not work
The cup light is referring to the outer most part on the torch tip, the purpose of the cup is to create a gap between the tip and the work piece. The light is indicating that the cup is worn and must be replaced.
Nov 09, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Welding Tools Logo
126 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
