Question about Canon IXUS 80 IS Digital Camera
Lens is stuck out of canon ixus 8015 - Canon IXUS 80 IS Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 10, 2010
How can I download video from my Canon IXUS 8015 to my Mac? The photographs download fine, just not the video. Thank you!
Try using iMovie. iPhoto and some other photo cataloging programs are great at dealing with photos but they don't do videos. That's what iMovie is for.
Sep 12, 2011 | Canon IXUS 80 IS Digital Camera
I can not download my pictures from canon 8015 to my pc using windows 7
Its possible that you need reinstall your drivers; try to download this from Canon site: software.canon-europe.com/products/0010567.
Select your OS (Operative System) to find it.
Hope this helps.
Jul 09, 2011 | Canon IXUS 80 IS Digital Camera
Is not a problemasking if my canon ixus 8015 was compatible in 4GB or 8GB sd memory card?
SD cards top out at 2GB. The IXUS 80 IS is compatible with SDHC cards, 4GB and larger.
Jun 27, 2010 | Canon PowerShot SD1100 IS Digital Camera
How to load canon ixus 8015 onto my Mac
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
May 17, 2010 | Canon IXUS 80 IS Digital Camera
I hve a canon ixus 8015 When I put photos from
Its a one way street...from camera to computer...not the other way around. Doing that will eventually corrupt the card and sometimes even the camera.
Jan 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a Canon IXUS 8015 digital camera with the lens stuck out. I've tried everything I've read on websites to fix it, from pushing the lens in, lightly banging the side where the USB goes in, battery in...
i too have had this problem,i sent it to be repaired and 4 months later it came back,then 2 days later it don eit again,so i took it apart,then i happened to have a compressor then blue everything out ,turnin it of and on until i tworked then blow every piece as u piece it back together,i stripped it as far as i could,now it breaks down lik e all the time,so i jus take it apart,ps when u turn it on or off ALWAYS have the lense facing the floor,this will help,actually i have a new problem with mine ,it takes pics but only on sum settings it wont allow me to see the pic on the screen as i take it,but it does actually take it,i tell u what i am sure off,cannon new this camera was shagged when they released it,my opinion they should give everyone double there money back for there stupidity
Jan 05, 2010 | Canon IXUS 80 IS Digital Camera
Canon Ixus 8015 ,lost user booklet
Hello, my canon us 8015 has just come back from repair , the lens would not open , i have been told this is a common problem on this model , is that correct..? thanks
Oct 27, 2009 | Cameras
Canon Ixus 860 lens
hi
If your lens comes out and retracs during power on or off then the spring that closes the lens is either broken or off trac. If you are within warranty period and able to open the case then it should be an easy fix. If not then you would have to get it repaired.
all the best.
thankyou.
May 05, 2009 | Canon IXUS 860 IS Digital Camera
Canon IXUS 80 IS Digital Camera Logo
236 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
