Question about GE JE1640 Microwave Oven
This unit has lights, fan works, inside dish rotates, BUT does not heat or defrost. Can you help?
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 10, 2010
Wheels under ring have wore paint off.. Can and what can I RE-PAINT THIS WITH
you can go to www. repairclinic.com and get it the parts necessaryGod bless you
Apr 04, 2013 | Sunbeam Microwave Ovens
The freezer works fine but the refrigerator compartment will not get cold.
remove the rear panel inside the freezer and assure that there is not an ice build up if there is you unit is haveing a defrost issue and or the fan inside this same area is not working here is also a link of how this happens and what may be the causes http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm you can do a continuity test on the defrost thermostat and the defrost heater most of the time it is the defrost thermostat that goes bad so you would want to check this first if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 31, 2011 | Frigidaire Microwave Ovens
Microwave doesnt heat, power is on fan is working
heatman101
klgjlgk
Jul 06, 2010 | GE JVM1540SMSS Microwave Oven
Microwave runs but doesnt heat
Runs ?? I guess you mean the light comes on and it rotates ??
Make sure its is on high cook mode ( in case someone has it on defrost etc) Try it with a half glass of water - if it does not boil, chances are your microwave unit inside the case has died - not uncommon fault and not worth getting fixed as the replacement part + labor is more than the cost of buying a new one.
Nov 07, 2009 | GE JE2160 Microwave Oven
Daewoo over the range microwave model KOT-21OUB just stopped working for no apparent reason. Lights and fans still work. Not heating food. Worked for one dish then the next nothing.
how old is the machine, microwave ovens have a tendancy to do the ridiculous for no possible reason. a check of the main power fuse within the unit might help. it is a large fuse 10A> that supplies the transformers
Feb 17, 2009 | Daewoo KOR-630A Microwave Oven
Maytag mmv1153BAB built in plate not turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either is a pretty simple job.
You need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 28, 2008 | Maytag MMV1153A Microwave Oven
No turntable, no heat. Light, vent fan and keypad all work...
That would be a problem with your primary interlock switch or its mount.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The interlocks are highlighted in the diagram below.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Nnt553w panasonic microwave. Whilst heating something he oven stopped and the display said refer to operating instructions. Now seems to be working but doesn't heat.
When you enter the time and press Start:
Does the inside light come on?
Does the turntable rotate?
Do you hear the internal cooling fan running?
Does the time count down?
May 25, 2008 | Panasonic Microwave Ovens
Oven works but does not heat or defrost
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
But your best bet is to reply back with your brand and full model number so we can possibly help you better.
May 20, 2008 | Sharp Microwave Ovens
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
GE JE1640 Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
