Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Not allowing water into dishwasher - Frigidaire 24 in. FDB126RB Built-in Dishwasher
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Oct 10, 2010
Why does it stop running after two mins and has an error code of OE?
The OE or Overflow Error code.
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
Feb 13, 2016 | LG LDF6810ST Stainless Steel Built-in...
Bosch dishwasher trouble shooting
check the incoming water line cor contaminte blockage..if possible use compressed air to blow it clear if blockage is present..some use a screen filter in the water hookup.. check this also..
Jan 18, 2014 | Dishwashers
How do you unclog the hose where the water goes into the dishwash
Close the tap. Remove the connecting end at the washer body. Flush the water through this pipe into a bucket or drain. Allow all the debris pass.
Now clean the filter which you can see inside the dish washer small threaded pipe end. You have to pull this and clean it. Re fix it back and try.
Apr 01, 2010 | Whirlpool DP940PWSQ Free-Standing...
KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Jul 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Not filling with water
Check your angle stop to make sure you are supplying water to the dishwasher. A lot of times after you install a new dishwasher, this is an easily overlooked step. If this is not your problem, it's probably in the solenoid for the motor that is not allowing the gate to open to allow water to flow into the basin.
Jul 04, 2009 | GE Dishwashers
Dishwasher water pump problem
Make sure the angle stop is open (the valve that comes out of the wall and is connected to the pipe that goes into the wall). This is what allows water to be supplied into the dishwasher basin.
Jul 04, 2009 | Frigidaire FDB1050REM Dishwasher
Dishwasher is leaking and backing up with water
Sounds like the door gasket is leaking allowing water to come out
Apr 29, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Bosch Dishwasher SHU3032 - pump will not shut off.
Kill power to the unit. Access bottom of unit removing the kick plate. Hard to see under the machine but you will find that water is collecting in the white plastic pan under the unit. Stick a corner of towel in where you see water to soak up the water. When all the water is out, turn the water pressure down on your supply line to almost nothing. Adjust this pressure by turning the hot water on at your sink and adjusting it down by half. This will allow you to use your machine until you can replace your water valve on the dishwasher. The valve is allowing too much water to come into the machine and over flowing at one of the inlet components.
Apr 10, 2009 | Bosch 24 in. SHU30 Built-in Dishwasher
When I start the cycle the water will not enterr the dishwasher. Is there a sensor somewhere that needs to be cleaned / repaired.
Just like a washing machine..your dishwasher uses an electrically operated valve ( inlet valve) to allow water to flow into it.. If that doesn't get switched on by the control system or is either clogged or defective.. you will not get water inside the dishwasher.. Normally, the dishwasher will not allow water into it if the door interlock is not made ( meaning the door is closed properly.. but you could have a bad interlock switch).. Hope thes ideas help you get it going.. ( I assume you have checked that youhave water pressure to the dishwasher before you posted your question)..if not.. verify you have water pressure coming into the DW... Hope this helps..
Aug 28, 2008 | Dishwashers
Dishwasher Accumulates Water When Off
Try turning water off to dishwasher and see if it stops it. If so, replace valve. If not check for a low drain hose loop, allowing drain water from sink to back up into dishwasher. Just raise drain hose as high as possible under sink and secure.
Nov 08, 2007 | Bosch 24 in. SGS43C12 Classixx...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
49 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
