Question about LG WM2075C Washer
LG WM2075CW Front load washer - hot/warm cycle works okay - cold cycle does not - when cold selected it does not sound like water even tries to fill but the cycle runs with no water - I removed the hose from the faucet and the cold water does turn on/off successfully - if I try to run cold cycle with hot water off and cold water on no water fills but the cycle runs - if I try to run cold cycle with hot water on and cold water on it runs with hot water.
  • LG Master
  • 2,131 Answers
Most likely the cold water valve. Easy fix
Posted on Jun 23, 2017
SOURCE: Washer takes forever to fill
You said you checked the screen at the faucet end, did you check the one at the washer connection? Most washing machines have a wire mesh screen which sits inside the plastic connector that the hose connects to. You will have to use a small pointed object (like an ice pick) to remove the screen and clean it. Be careful not to damage it, I have ruined them on more than one occasion and had to replace it with a new one. If that is not the problem, there is likely a problem with the valve that is controlled by the hot/cold knob. I am not familiar with your washer brand, but mine required quite a bit of disassembly to get to the valve and switch, and in my opinion is a job better left to the local repair man.
Posted on Jun 04, 2007
particleman
  • 9 Answers
SOURCE: No hot water entering
1. Make sure water comes out of the hot water hose into a bucket.
2. Check to make sure the solenoid valve is working. The buzzing is the 60Hz on the coil and can make a lot of noise if valve does not operate properly. Try blowing into the hot water port. If the solenoid is functioning properly air will move freely, if not its stuck.
Posted on Jan 10, 2008
Healeyman
  • 1198 Answers
SOURCE: Whirlpool model LSR7233EZO / doesn't fill fully
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
Posted on Jul 29, 2008
SOURCE: Washer fills and will drain but not wash.
I found brushes at this site.
http://www.appliancepartspros.com/modelsearch_model.aspx?part_id=2822714&&model_id=232480
You might want to confirm your model number etc.
I'm told I can get a whole new motor for about $207.00.
I wonder if it would be any quieter than this one.
Got that "jet taking off" sound during spin in my present motor.
Posted on Oct 02, 2008
DRACO A5OG
  • 22 Answers
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Posted on Dec 31, 2008
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washer fills only with cold water. if warm or hot is choosen, you hear a noise (sounds like something is straining) but no water comes thru. but the washer continues as if water has come thru.
try taking off the hot water hose(from the wall) and make sure the hose has no obstructions. My did the same thing,after I cleaned it out it worked fine.
Aug 17, 2010 | LG WM1812C Front Load Washer
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
LG front load washer. Clothes are warm/hot at end
got me on that 1 , i'd call the nearest appliance shop explain to them whats going on and see what they say
Jun 16, 2009 | Washing Machines
Never Runs Cold Water LG Model WM0532HW
When set to Cold it Fills Hot ?
What does it rinse with ?
Have you had the fill pipes off the back for some reason and put them back wrong or has a plumber been messing with the supplies
If the machine is told to fill cold it should, it should also use cold water to rinse with.
What hapens if you tell it to fill Hot only
Jun 13, 2009 | LG WM-1832C Front Load Washer
I have tried several times to use cold cycle and the clothes always come out very hot this even happens on the warm cycle. Why wont my machine except cold water?
this can get indepth but first check your hoses and make sure cold is cold and hot is connected to hot. then check the valves by selecting a hot cycle and check water at filling to see if it was cold or hot, if your unit has a heater make sure you dont select sanitize or very hot. then post correct model and heater info. to advise further
May 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Hot water goes into cold water washes
Jan 12, 2009 | LG WM-1832C Front Load Washer
LG WM2075C Washer Logo
124 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
