Question about Maytag Refrigerators
Model MSD2651HEQ Mattag side by side refrigerator-- the water filter will not release from the filter head. After several attempts the water will not dispense and the old filter remains in the head. what next? Sandy Hilborn
  • nhilborn Oct 10, 2010
    This filter has being changed several times but always hard to remove -- this time the filter turns hard and wants the head to break away from the holding bracket- what next- there is not space to use two wrenches.-- dynamite is not the solution.
    President:
  • 2,777 Answers
Wow that's a nasty one, so it will not release no matter what you do? I'm not sure even where to point you on that issue. Is it just screwed on so tightly that you can't release it? Give me a bit more detail and I can definitely help.
Thanks
Tim
Posted on Oct 10, 2010
  • Tim Grayson
    Tim Grayson Oct 10, 2010
    Yikes, if it's that badly stuck (and it sounds like it is since you have been able to remove it successfully in the past) you are going to want to employ the services of a professional Maytag person. That way if they break it (which is likely from the sound of it) they will pay for the repairs themselves as opposed to you breaking it and doing hundreds of dollars of damage to your fridge. I just wouldn't mention that it is badly stuck ahead of time, just feign ignorance and tell them you need them to change the filter... Let them figure out that it's stuck and have them do the replacement. Trust me it will be well worth the small service visit charge to ensure that the fridge is not damaged, and if it is - they will be liable.
    Thanks
    Tim
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Mar 23, 2011 | Amana ARS266ZBS Side by Side Refrigerator
Filter stuck in a Frigidaire FRS26R4A Side by Side Refrigerator. Tried and tried but pushing the release button does nothing. I've tried using a hefty screwdriver to pry it out while pushing the release...
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Dec 06, 2010 | Frigidaire FRS26R4A Side by Side...
Am attempting to change an in grill water filter for my whirlpool side by side fridge, and cartridge seems jammed, cannot turn anti-clock wise to release. Do not want to force in case I break it. Any...
Use one wrench to hold the water line and another one on the filter to avoid braking the line, the filter should give up.
Don't forget to rate this post!!
Sep 19, 2010 | Whirlpool GS6NBEXR Side by Side...
Mattag PSB 2151 Side by Side Fridge/Freezer. Water is dripping out at front corner under freezer side everyday. Defrost Thermostat?
Most likely plugged up defrost drain hole. Do you see any frozen water (ice) in bottom of freezer? If so then remove lower back wall of freezer compartment and use a turkey baster with some hot water to "plunge" the defrost drain tube till the water starts to flow. Clean up excess ice and away you go!!
Jun 14, 2010 | Maytag PSB2151G Side by Side Refrigerator
Water leaking in freezer Maytag MSD2651HEQ side by side
you need to open the back of your freezer there is a hole for drain in the bottom...
clean it with hot water and pump so that way you clean the path to the drain pan next to the compressor.
The path might be frozen so use hair dryer at first... good luck let me know if you need more help.
Arik
Jan 11, 2010 | Refrigerators
CAN NOT REMOVE WATER FILTER FROM PLASTIC HOLDER
it will also state to turn of the water supply and release any pressure
Jul 02, 2017 | Maytag MSD2651 HE Side by Side...
Cannot remove water filter from LG 26 cu ft side-by-side in the d
Here's the only thing that worked for me in getting the water filter out of my LG refrigerator after trying for three weeks, pulling hard by hand, using high-grip gloves, and trying an oil filter wrench. You have to break or lessen the suction created by the water in the filter. Do this by first turning the filter to the Removal position (in my case, a quarter-turn to the left). Then grip the filter tight and rock it back and forth slowly as far toward the back and front of the refrigerator as possible, while keeping a bit of downward pressure on the filter. This lets the two O-Rings "walk" their way down the insert tube. After only a few pushes and pulls - voila! -- it lets go and will drop right out.
Nov 24, 2008 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
I have the opposite problem
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag Frig. Model MSD2651HEQ not working
Your start relay for the compressor is probably the problem. If ordered, you will most likely receive the relay and overload protector. Replace them both.
Sep 27, 2007 | Refrigerators
Refrigerators Logo
59 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
