Question about Dryers
Not heating, takes 2 - 3 cycles to dry. Is it the element
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 10, 2010
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Laundry not getting dry
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Jul 18, 2009 | Dryers
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
My dryer takes 3-4 full drying cycles to completely dry.
Since you do have some drying hapening, it is probably a lack of total heat.
Most all dryers have 2 heating elements. One for low heat and both for hi heat. Sounds like you lost one of the elements.
On electric dryers, look for:
1. Safety device has tripped and not reset or has malfunctioned.
2. An element has burnt out. Or a wire to the element has fell off or burnt off due to loose connection.
3. Exhaust system is clogged or restricted, causing safety to active. This stops the heating process. (Don't forget the internals of the unit being clogged too.)
4. Not getting full power to the unit. Reset breaker and verify that full power is to the unit.
(Usually somewhere between 208 to 240 volts, depending on where you are at and the manufacturer of the machine.)
5. Timer has malfunctioned and needs replacement. This does effect power to the elements.
Check these out and let me know how you come out.
Please keep in mind that there is the possibility that a new unit may be cheaper than repairing the one you have. New units have warnanties too.
Choose wisely grasshopper. And Good Luck on your getting it going.
May 11, 2009 | Dryers
Dryers Logo
35 people viewed this question
Top Dryers Experts
