Question about RCA HD52W66 Projection Television
Hd52w67 i have a damn rainbow!!! on my tv. i have a convergence issue and would like the part # for it.
  • RCA Master
  • 5,138 Answers
Open FUSE FL231. next to FBT onright side 3 of them in a roll.
Posted on Dec 26, 2008
I see rainbow on my color screen tv rca model r52wh74 color issues.
The problem of your tv is the convergence try to adjust it manually in the setting of your tv. If still same or no effect the convergence IC is already defective. You can find it inside your tv it is connected to a large aluminum called the heat sink it has a marking of stk- followed with a number.Try to replace it.
Jun 07, 2011 | RCA R52WH73 Projection Television
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
Hitachi projection TV - video is in 3d rainbow
This sounds like a convergence circuit problem. Your set has two convergence IC chips (integrated circuit). One is for the red CRT, the other is for the blue CRT. This is a common issue with projection TVs. It is not a difficult repair if you have any experience with electronics and soldering. Both convergence ICs should be replaced at the same time. The part is IC (STK394-160E) and is available for around $36 or less. If you have a shop fix this they will likely charge $300-$400. If this information was helpful or if you would like to know how to do this repair in more detail post back on this thread. I would be happy to walk you through it.
Dec 02, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Sometimes I get a rainbow on the bottom of the screen.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Philips 60PP9202 60" Rear Projection...
Green rainbow streak on bottom of TV PT-47Wx49E
If Convergence on setup dosen't work, And you think its not STK Convergence chips!, Then "Yes" It more then likely will have a few open Resistors!... (Near STK chips)
Jun 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Service Manual
You can get the service manual emailed to you at the following link. The manual is listed under Thomson the ITC222 chassis is a thomson which is RCA It cost 12.99 but they provide free on line tech support to help you with your diagnosis and repair and they also sell parts with free installation instructions.
http://servicemanuals.vstore.ca/
Apr 13, 2008 | Televison & Video
Convergence
Okay, usually the parts that go bad to make the convergence option drop from the menu are the following. Fusible Link (FL1231) Diode (DP1231) and capacitor ( C1230) the numbers in parenthesis are the actual component locations on the board. These items fail causing the set to think its a direct view set instead of a projection unit.
Rainbow circle in middle of my tv
Start bt realigning the convergence by using the auto focus switch. If this doen;t work, you may have a bad convergence chip. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 04, 2007 | Hitachi 42V710 42" Rear Projection HDTV
RCA HD52W66 Projection Television Logo
116 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
