Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair build up from our beloved Golden Retriever + dust + my own hair, like an inch thick. I vacuumed the front of the coils last night. Still did not cool well 12 hours later. It had made ice, but the ice was shining with a little water on it. I cannot set the temperature controls to zero (freezer) and 34 for the unit, because it keeps going back to 6 degrees and 36 on the frig side, on the control. Today I pulled the back panel to access the electronics. The compressor was red hot. The fan was not working. I turned the unit off. I set up a big industrial fan and aimed it into the entire compressor area. After the compressor and area cooled off for 30 minutes, I plugged it back in and the fan was working. But the compressor still gets very hot. Anyone have any ideas? THANK YOU VERY MUCH!!! (I put thanks in caps to emphasize how much I appreciate any input.) Best, Beth
  • pashamedia Oct 10, 2010
    THANK YOU heatman101! (((HUGS))) Beth
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 10, 2010
Testimonial: "Heatman101 TY X 10! Compressor fan starts. Freezer fan also is working. But how hot should the compressor get? Still gets real hot! TY"
  • D. Floyd Kolb
    D. Floyd Kolb Oct 10, 2010
    When running for long periods of time and especially on a start up the compressor will get to 200F or better... hot enough that you do not want to be touching it!!!
    But the hot gas coming out of it will make it very hot in some spots...right where the cool gas goes back in it will be fairly cool....
    So the best practice is to give it as much air and keep it as cool as possible to get it running the most efficiently possible...
    heatman101
    Dear Heatman101, this "repairgirl" just pulled off all the screws and so on to access the coils in the freezer. No ice or frost there. Fan running fine. OMG 15 minutes just to check that! So that is OK. I have put the industrial fan on the open port to the compressor in the back of the ffrig, down below, to give it ventilation while it gets back up to speed. Will not put the cover panel back until tomorrow morning. THANK YOU for saving the freezer foods etc. You are what makes the web a GREAT place!! (((HUGS))) Beth
Whirlpool Gold Model GS5SHA Side by side. Freezer working, refrigerator side not getting cold.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 06, 2010 | Whirlpool Refrigerators
Whirlpool Gold GD5SHAXLQ02- Serial number SP3131657 just stopped cooling. Neither the fridge and freezer seems to be cooling. This unitl is about 7 years old.
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear. Once this is done, restart unit.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate.
Don't forget to rate this post!! Good Luck
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a 1999 Whirlpool side by side refrigerator and Freezer. Model number ED25EQXFW02. Last night the Refrigerator and Freezer stopped cooling and freezing. After taking everything out of the freezer,...
Usually when the freezer is still giving cold but the frig is not receiving cold you have an ice build-up on the cold (evaporator) coil that is hidden behind the rear panel of the freezer compartment. If you push on this panel, you usually will hear a cruntch sound (this tells you there is ice/frost on the coil). There are 3 components that affect this problem: defrost timer, defrost stat, defrost heat coil. In other words, something is not working to remove the frost from the coil and it is building-up day after day (takes about 5-7 days to become full (blocked). When this happens, no air can move over the coil to take the cold away and blow it throughout the frig or freezer compartments.
To access the defrost coil or stat, you have to ren move the back panel (in the freezer) and remove all the ice with a hair dryer only or let the door open all day and allow it to melt. DO NOT PUSH OR PRY OR CHOP WITH ANY TOOL OR YOU WILL BE GARRANTEED TO PUNCTURE A HOLE IN THE COIL AND YOU ARE REALLY SCREWED. The time is either: under the front of the whole refrigerator, or in the frig compartment (towards the back or attached to the ceiling of frig compartment). If you have some experience with electrical parts, you can test to see which part is at fault. Good Luck. Macgivor
Oct 11, 2009 | Whirlpool Refrigerators
Freezer/Fridge not cold enough
check see if compressor on check control if on
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold 25.4 cu ft side by side
After cleaning the lint you need to give the unit at least 24 hours to recuperate. If you try letting it run for 24 hours and it still doesn't work let me know if the compressor (the main motor) and the fan underneath is working and the fan in the freezer is working.
Nov 24, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frig and Freezer not working.
Beware I bought a Frigidaire side by side in 2006 and the compressor went out in March 2008, the warranty was out in Jan, and the repair man came out and said it was a 2004 model, you might have the same one as I had, they know the compressors are bad in the frig's and you only pay,$160.something if I remember. It sounds just like the problem I had, good luck!
Mar 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
369 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
