Question about Emerson CR202EM9 TV
In menu mode, television will not respond to add/delete command. only lets me view ch 3 and 12. how do I get it to respond to this command and let me view other channels
  • 4 Answers
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Tip
Service menu codes vizio
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
L32
With power off, hold Ch UP and Ch Down together for 10 seconds.
While still holding Ch up and down together, push power, then let go.
Select OSD button, there should be a letter "F" in the lower right hand corner of the menu.
Then hold OSD and Mute/Exit buttons together until factory menu comes up. Make adjustments with remote, select exit, then turn off power to save the adjustments.
on Apr 29, 2015 | Vizio Televison & Video
Forgot administer password
Which password? Bios? Windows? Linux? Mac?
May 11, 2015 | Acer Aspire m5640 PC Desktop
How do u add and delete channels on a rca 24F512T
1) Make sure that the current input is TV. Then press Menu on either the TV or the remote.
2) Press Ch+ or Ch- to highligh Setup then press OK.
3) Press Vol+/Vol- to highlight TV or CATV as needed for the channels you wish to add or erase.
4) Then use Ch+/Ch- to highlight Channel and then press Vol+/Vol- to enter the channel number that you want to add.
5) Press Ch+/Ch- repeatedly to highlight Add/Erase then use Vol+/Vol- to select whether to add or erase the channel selected above (step 4).
6) Press Menu repeatedly to exit the OSD (or wait until the OSD closes after a period with no key presses).
Then use the Ch+/Ch- buttons to scroll through the channels in memory to see the change.
The manual for your 24F512T is available here: http://support.ttetech.com/RCATV/Assets/pdfs/24F512T_1641309F_IB_e-06.pdf . See page 13 of the manual for extra information on manual tuning and page 15 to add and remove channels from the channel list.
I hope this helps.
Mar 27, 2011 | RCA 24F512T 24" TV
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
How do I do get to the set up mode using controls on the TV set? Want to do a channel search
Hello
To autotune do the following steps.
1.1 Press MENU to access MAIN MENU screen,
then press CH UP (8) or DOWN (9) to
move the " " mark to "SET UP".
1.2 Press VOL (+) or (-) to access SET UP
mode, then press CH UP (8) or DOWN (9)
to move the " " mark to "CH SETTING".
1.3 Press VOL (+) or (-) to access CH
SETTING screen.
1.4 Press CH UP (8) or DOWN (9) to move
the " " mark to "CH SEARCH", then press
VOL (+) or (-) to access CH SEARCH
mode.
START
2.1 Press VOL (+). The tuner will search
through all available channels in your area
and add them into the TV's memory.
STOP
2.2 Press VOL (-). CH SEARCH will stop at
the current channel and will not add any
higher channels.
2.3 Press MENU to exit.
Nov 21, 2010 | Sharp 25K-S180 25" TV
I am running Windows 7 and some how I lost my toolbars, File, Edit etc
To add a toolbar, click Tools, then Toolbars from the Command bar or right-click on the Command bar to see a list of toolbar options. You can activate or deactivate a number of Internet Explorer toolbars from this menu option. You can even Lock the Toolbars to make Internet Explorer show the same toolbars each time you use the browser.
To add or remove Add-ons, click Tools from the Command bar and select Manage Add-ons from the drop-down menu. From this menu you can view and manage a list of different Add-on Types you've got installed in the browser. To add more, click on the Find more providers... option at the bottom of the window. To delete an Add-on, highlight the one you wish to remove and select Remove, or select Disable if you wish to leave it installed but make it inactive.
Nov 08, 2010 | Compaq Computers & Internet
Website toolbar is not showing up
To add a toolbar, click Tools, then Toolbars from the Command bar or right-click on the Command bar to see a list of toolbar options. You can activate or deactivate a number of Internet Explorer toolbars from this menu option. You can even Lock the Toolbars to make Internet Explorer 8 show the same toolbars each time you use the browser.
Oct 17, 2010 | Microsoft Internet Explorer 8
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How do I do a channel scan?
Press Menu on the TV (second button from the left) or the remote. Use the Vol + / Vol - buttons to highlight Tuner, only available when the input is the TV (press TV/AV to get to the correct source) mode. Press Ch+/Ch- to highlight AutoProgram and then Vol+ to start the search for channels. The TV will show Tuning Finished when done and then go to the lowest channel found. If you want to add or remove stations, tune to the desired channel, then press Menu, and highlight Tuner, Ch+/Ch- to highlight Add/Erase, then Vol+/Vol- to set Add or Erase. Press TV/AV/Exit to get out of the menu.
I hope this helps.
Jul 28, 2010 | Philips Magnavox 27MS343S 27" TV
Emerson CR202EM9 TV Logo
115 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
