Question about Radio Flyer Pathfinder Wagon
My two front wheels on my pathfinder was put on wrong, how can I get the silver part off
Why does 4wd button blinks but front driveline moves. is the 4wd engagedon a 2004 tundra?
Probably because you have engaged the 4x4 on and have forgotten to switch it off. I have a Pathfinder and it does exactly the same. However, my Pathfinder light only flashed when in lower gear combination and the strange thing is you cannot really go faster, as the gear train is in low revolution and the engine in high revolution. So, to fix this unexpected problems that occurs (sometimes) when you've engages 4x4 drive while the front wheels are in a turned position - either left or right, is to put it in reverse after you've switched the 4x4 system off, straighten the front wheels and let it reverse a couple of metres. You should see the light disappearing, and you're now in two wheel drive. Put the selector in Drive and off you go. If the problem is not what I think it is, then it's best you send it to a dealership where you purchased the vehicle. Normally they're under a three year warranty, so you should get a free inspection.
Sep 01, 2014 | 2004 Toyota Tundra SR5
1999.5 nissan pathfinder has loose steering wheel
My '98 Pathfinder had a lot of excessive play in the steering wheel. I had a big chuck of rubber missing on the front end that had apparently worn out over time. It cost me about $1400.00 to fix it from the dealership.
Mar 25, 2013 | 1995 Nissan Pathfinder
1986 nissan pathfinder
Hi Melissa,here's a guide to your front wheel bearings.
Feb 11, 2013 | 1997 Nissan Pathfinder
I just got my hands on a 95 Pathfinder. The front tires have a lot of wear on the inside edges. I was told by seller that this is caused by driving on pavement in 4WD. As this is my first 4x4, I wasn't...
I'm guessing the lower ball joints are shot. This will cause the tires to lean in on the top and and wear the inside of the tire. I could be wrong! Try jacking the front wheels up and support the vehicle on jack stands, now grab the tire top and bottom and try to rock it in and out. If there is movement, you will have to have someone watch to see what is moving, while you rock it. If it's the ball joints, they will need to be replaced before you can align it. This can be spendy, there's a lot of labor involved.
Mar 27, 2010 | 1995 Nissan Pathfinder
How do I get the front brake rotors off a 1999 nissan pathfinder, 2 wheel drive
First block the rear wheels so they won't roll.
2. Jack the front end up and put on jack stands don't trust the jack for long periods of time.
3. Remove front wheels and brake calipers.
4. In the center of the rotor as you look at it is a dust cover remove this
5. There should be a lock cap with a cotter pin thru it, remove the pin and lock cap
6. Remove the nut holding the bearings in place.
7. Remove rotor by pulling toward you, be careful the bearings will come out also, don't let them fall or get dirty.
8. There is a seal in the back of the rotor to give access to inner bearing.
9. Replace seals and repack inner and outer bearings and reverse to install. Being careful not to over tighten the front wheel bearings. If you do they wil sieze up then you have a real mess.
Sep 27, 2009 | 1999 Nissan Pathfinder
Front wheel shaking in my pathfinder 1998
I have a 1994 explorer that did the same thing and what I had to do is change the radius arm bushings as well as ball joints and tie rod ends - this seemed to fix it, however yours may be a little different but that is where I would start
Jan 19, 2009 | 1998 Nissan Pathfinder
Speedo not working on nissan pathfinder
check the speed sensor either at the transmission or on the front wheel axle. You have to remove the front wheel , rotor until you get down to the shaft. The speed sensor is right there on the passenger side of your car.
Jan 06, 2009 | 2002 Nissan Pathfinder
99 nissan pathfinder 4 wheel drive once put into 4 wheel drive popping noise underneath the vehicle
that sounds like a bad universal joint on the transfer case to the front axle. have that checked out
Oct 01, 2008 | 1999 Nissan Pathfinder
Front passenger wheel
Could be a few things. Bad ball joint, cv joint, or others. But I'ld start with the CV joints. Basically, your axle shaft. First way to tell if that's the prob would be to put truck in 4 wheel drive, LOW gear. This will lock up all four tires. Then jack up that corner of truck. If the tire only moves a little before you can't anymore, it's fine. But if you can spin your tire completely, odds are it's your cv joint.
Sep 06, 2008 | 1997 Nissan Pathfinder
Radio Flyer Pathfinder Wagon Logo
53 people viewed this question
Top Radio Flyer Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Radio Flyer Cycling Expert? Answer questions, earn points and help others
