Question about Maytag Appliances Over-the-Range Microwave Oven
My MMV4203DQ00 micro was installed on Sept. 3, 2010. For the last week, the turntable will not turn.
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 10, 2010
Why would the turntable stop turning and the unit stop heating?
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
Sep 06, 2014 | Sharp R-1505 Microwave Oven
I have a combination oven and microwave model # J KP86BOF1BB manufactured Nov 2002. For about a week there was a slight burning rubber smell when using the microwave and now it does not heat anything. The...
It's probably the magnetron which some companies provide an 8 year warranty on for parts but you'd be responsible for labor. Unless you have an extended warranty, it's probably cheaper to buy a new one than to repair this one. I tried to look up your model number but doesn't seem accurate. Do a little research, there could be a known defect and the company may help even though it's out of warranty.
Nov 19, 2012 | Microwave Ovens
Microwave mod# MMV4203DQ00 - turn table does not turn
Sounds like the motor is faulty.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 03, 2011 | Maytag Microwave Ovens
My Kenmore 721-63259301 manufactured Sept. 2007 recent stopped working. I first noticed the issue as I went to reheat some leftovers. The unit powered on (internal light lit up turntable rotated timer...
Sorry I can't help you but we purchased this same model 11 months ago and ours just stopped heating this week. Sure expected it to last longer than this.
Jun 12, 2010 | Microwave Ovens
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Whirlpool MH1150XMB
there is a motor under the turn table that spins that tray.now some more expensive units would allow you to turn off the turn table if user wanted to,so check that out .but if not and its under warenty call a sears or any servicer that repairs you brand under warenty
Jan 25, 2009 | Magic Chef CMV1000B Microwave Oven
Turntable will not turn
If everything works, light and micro heating.. then I have 4 possibles for you to check... 1st make sure you don't have a button that allow you to turn the turntable on/off... 2nd take the glass table out and check the center plastic spinner(pull it out) and see if its broken. 3rd your turntable motor is bad, and 4th the relay for your turntable on control board is bad... helpfully that will do it for ya.. good luck.. mike
Dec 20, 2008 | Kenmore 62622 Microwave Oven
I have a gold star above range microwave, mvh1615ww, man. in Sept. 2006, the turntable is not turning, any quick fixes?
Try the TURNTABLE ON/OFF pad. Touch this pad to turn off the turntable or turn it back on. “OFF” will appear in the display when the turntable is turned off.
Do you mean MV1615?
If so, we have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
You may need a new turntable motor or coupler.
Aug 17, 2008 | Goldstar Microwave Ovens
Hi, My new Whirlpool microwave oven's turntable stopped working after a few weeks. It was installed in June, 2008. I called last week and a service rep. advised me to unplug and restart after 10...
Since it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting Whirlpool customer service here to get it fixed free under warranty.
I'd say the motor or coupler has failed.
Aug 06, 2008 | Whirlpool Microwave Ovens
Maytag Appliances Over-the-Range Microwave Oven Logo
88 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
