Question about Ace Hardware Ace & Electric Staple / Nail Gun
How do load stables for model 2064673 - Ace Hardware Ace & Electric Staple / Nail Gun
I'm looking for a stable ride, should I pick a small or a large hydration pack?
Smaller packs will be more stable on your back. Envision a pack when it's fully loaded and how it will ride on your back. If you anticipate carrying large loads, look for a waist-belt.
Sep 06, 2012 | Burton Camping, Backpacking & Hiking
What's the best way to hook up 2 Hifonics hdl12d4 subwoofers to a mono amp
Ok, your post has two different models listed. Let's start with something you need to know about your amplifier. Is it one ohm or two ohm stable. This will make a difference. Also, whether your subs are single voicecoil (HFI12s4) or dual voice coil (HDI12d4).
Let's start with the easy scenario. Let's say your amp is two ohm stable and you have two single voice coil subs. It's simple. You go from the positive of the amp to the positive of both subs and the negative of the amp to the negative of both subs. This will provide a 2 ohm load to the amplifier, thus pulling all the power out of it.
Unfortunatley, if you have two dual voice coil subs, you won't be as efficient. You will only have the options of a 4 ohm load or a 1 ohm load.
This is where having a one ohm stable amp would come in handy. If the amp is one ohm stable, hook the positive of the amp to all 4 of the positives on the subs, and hook the negative of the amp to all 4 negatives of the subs. This produces a 1 ohm load.
WARNING!! If you have a 2 ohm stable amp DO NOT use the last wiring scenario. It will fry your amp.
Now, the last is a little trickier. This is for two dual 4 ohm subs. Follow closely. Hook the positive of the amp to one of the positives of each sub. (do the next step to both subs) Go from the negative of the voice coil that you hooked positive from the amp is hooked to, and hook that to the positive of the unused voice coil. Then go from the negative of that voice coil and hook to the negative of the amp. Make sure this is done on both subs. This will give you a 4 ohm load.
Hope this helps
Aug 31, 2011 | Hifonics HFI 12S4 12 DVC Subwoofer 600...
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Sep 23, 2009 | Kenwood KAC-9103D Car Audio Amplifier
How to connect a 2 ohm stable in stereo
ok when getting into wiring and impeadances on car audio one must be careful the wrong impeadance with the wrong amp causes overdriving and it will kill your equipment. check the user manual to see if the amp is 2 ohm stable if it is dictated as stable @ 2 ohm there are multiple ways of wiring the speakers to get the load you want i highly recommend 12volt.com
Feb 18, 2009 | Sony XM-2150GSX Car Audio Amplifier
Nedd help kicker kx1200
it should power them fine but you will have to make sure you do not wire them where the ohmn load is below what the amp is stable at most of the are 2ohmn stable you can use a mutimeter in the ohmns setting to determin this
Oct 31, 2008 | Kicker KX1200.1 Car Audio Amplifier
Ace Hardware Ace & Electric Staple / Nail Gun  Logo
203 people viewed this question
Top Ace Hardware Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Ace Hardware Tool and Hardware - Other Expert? Answer questions, earn points and help others
