Question about GE GSS25SGMBS Side by Side Refrigerator
Refridge not cooling
The refridgerator is not cooling. fan works, compressor does not seem to kick on
  • 943 Answers
Hi thanks for the question . yes look at the compressor the start relay is burnt out replace it that should solve the problem thanks the appliance doc
Posted on Sep 28, 2008
Ge refridgerator model sts16abserww, stopped cooling, down at the compressor I hear a slight click then wait a few seconds and hear another click (NO buzz between clicks), then wait a few minutes and the...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Refrigerators
I have a Magic Chef Refridge MCBR 1010W that has stopped cooling, fan runs and you can hear it kick in but then kicks off? An Ideas?
If the compressor kicks in that tells you the compressor relay and board are probably good. HOWEVER, when you say it kicks off right away that is not a good indication! It sounds like a compressor problem. Is the compressor extremely hot or is the condenser coils icing up? If so, I wouldn't invest the money into repairing it, because it would cost more to repair than to replace.
Jun 16, 2011 | Magic Chef MCBR440 Compact Refrigerator
My refridge and freezer stop cooling fan is
check the overload relay, see the motor compressor , on side ot its body had a small box where the wiring goes in, open it and check the relay , see if still have continuity or better yet replae.
Oct 31, 2009 | Kenmore Refrigerators
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Mar 10, 2009 | Maytag MSD2651 HE Side by Side...
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Dec 25, 2008 | GE PSS26SHRSS Side by Side Refrigerator
HOT POINT NOT COOLING WELL
if the condenser fan ( the one near the compressor) is not running and the compressor is running, then that's not good. try to lubricate the bushings of the fan and see if it would run. feel the blade if it turns smoothly. if it's sticcky, then there is your problem.
it should be running the same time as the compressor. if the compressor stops, the fan should stop too.
tnx 4using fixya,
drcool
Sep 26, 2008 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Frigidaire side by side refridge
pull the kick plate off under the doors. if you look in behind the kick plate youll see alot of dust build up. this area needs to be cleaned once a year to keep air flowing properly over the condenser coils. if the dust build up is minimal then remove back panel of refrigerator and make sure the fan is running behind the refrigerator. if not, or if running real slow replace the fan motor. the heat is the because the condenser is getting too hot. it needs to be fix or the compressor life will be greatly shortend
Nov 20, 2007 | Refrigerators
GE GSS25SGMBS Side by Side Refrigerator Logo
151 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
