Question about Jensen Televison & Video
MY JENSEN TV WILL NOT TURN ON, THE RED LIGHT BLINKS. CAN U HELP?
    Scholar:
  • 143 Answers
The red light is the error code. Count the number of times it blinks and that is the code you need to search for. The model number of the TV is also needed in order to diagnose it.
Posted on Oct 10, 2010
I have a 27 inch Jansen TV. Remote is lost. I have a universal remote. What codes do I need to program the remote ? and will this code work for all remotes we can buy from Target or Wal-Mart ?
Hello
Three digit remote setup codes for Jensen TV are:
004/ 009
Four digit codes are:
0004 0009 0133
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
CODE SEARCH METHOD
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Aug 18, 2011 | Jensen Q2749J 27" TV
What was the code did all work cause i can not get it to work at all
Hello
Just try one amoung the following codes. I've only these three codes are available with me for Jensen Tv.
{ 0004 _0009 _0133 }
Proceedings
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Note:- If one amoung the above four codes did't work, try the other after the TV is switched off and switch in again after some time, say at about 10 seconds, and try the other. Not enter the code continously without turning it off, after one code won't work. Ok.
__________________________________________________________________________________
Oct 25, 2010 | Jensen TS2050J 20" TV
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Screen doesnt turn on
try selecting the dvd or tv modes ... if that doesn't help , reset the system and start all over.
Nov 10, 2008 | Jensen VM9510 Car DVD Player
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Jizzz i´m desperate!!!!
jenson 300 series Sony tv codes 497,491,475,459,406 or the code you have
hold the program or setup button untill it blinks. select the tv function and enter the code you have or one i listed above then enter
Or if your remote is this 300c series your code would be 0000
you would press down and release the device"mode key"tv,vcr,ect
the red light will blink once.press and hold down the setup key untill red light blinks twice then release.enter the code the led light will blink once on each digit execpt the last one will blink twice to confirm valid code ****mode 1 is for the tv on this remote.
hope this helps
Mar 18, 2008 | Jensen JER-323 Remote Control
Programming the jensen jr400 universal remote
1) Turn on the Proton TV;
2) Press the "TV" button on the JR400;
3) After releasing the button, the red LED indicator should blink twice;
4) Press and hold the SETUP button until the LED blinks twice;
5) Release;
6) Enter 9-9-1 on the numeric pad. Red LED blinks twice;
7) Press POWER;
8) If TV doesn't turn off, press TV again;
9) Repeat #4, #5, #6, and #7. If TV doesn't turn off, go back to #4, until the TV responds.
10) Go on to the next device, i.e. DVD, VCR, etc.
Feb 17, 2008 | Jensen JR400 Remote Control
Jensen (143307) Remote Control
Turn on your tv manually. (without remote)
Hold on to the (tv) button and on/off button for the same time for 3 secs.
On/off button will light up.
Push on/off button until the tv turns off. (1x-10x)
Then push the stop button on the bottom of the remote to save.
Dec 08, 2007 | Jensen 143307 Remote Control
Televison & Video Logo
123 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
