Question about RCA Televison & Video
Rca projection tv turns on and quickly turns off
  • slamnjamn May 31, 2008
    Here is some additional info on this issue. I have an RCA 52 inch Home Theater rear projection TV model # P52770EB and the Chasis #PTK169PABS. The issue is that the TV was fine until one day it would not fully turn on. by this I mean that when I hit the power button it wants to turn on and i can quickly see an image of some sort, but it quickly turns off. There were 2 incidents were my daughter managed to hit the power button and it stayed on for a while, but when we shut it off we could not turn it on a again. We were able to get it on 2 times, but it was a hit or miss. Any ideas on what I need to do or replace?
    Problem Solver:
  • 14 Answers
Once you turn it on again DONT TURN IT OFF. Really though i wish i could help you here i have no idea what your problem is. Personally if it was me i would think power supply but that doesnt even sound like a full proof solution. Have you tried talking to a technician?
Posted on May 31, 2008
Squeaking tv
If you have an AM radio/ other electronic device that is not well shielded close to some TV systems, it can also cause this type of sound in Stereos, turntables, computers etc... a lot of the time it is really easy to track down.
OR
You have a bad electrical ground in your apartment/House that needs to be checked quickly. Feedback is rarely a good thing!
P.S. you should always have your electronics all running off of the same ground via a surge protector of some type.
Hope this helps
Sep 18, 2009 | RCA R52WH73 Projection Television
Rca p56830bl picture fade out
sounds like a vertical and horizontal deflection issue..maybe your control board is unhappy.
you inclined to do this work yourself?
Apr 28, 2008 | RCA P56830BL 56" Rear Projection...
Printable user's guide for rca 20f420t tv thank you
You can download the user's guide from RCA here:
http://tv.rca.com/RCATV/Assets/pdfs/20F420T_16680240_IB_e-06.pdf
Please take a moment to rate this solution. Thanks for asking here!
Mar 04, 2009 | RCA Televison & Video
RCA P46920 TV will not turn on, it makes a beeping noise.
Shorted horizontial output transistor q14401 -I think- and bad flyback transformer(high voltage transformer).The noise is the power supply starting and shutting down very quickly because of the shorted transistor.Very common problem,but some of the flybacks are no longer available from RCA.Sometimes you can use generic but questionable life on some of these.
Jan 11, 2009 | RCA P46921 46" Rear Projection Television
I have a 52" RCA
Check your DMD board fan. Make sure it is spinning. This fan is the #1 problem for this model not turning on. This fan keeps the DMD board cool while working and if the fan does not spin your TV will not turn on. You might need to replace it if it is not spinning. If the fan is spinning, then check the color wheel. If it is not spinning your DMD board is not working and should be replaced.
Mar 23, 2008 | RCA R52WM24 52" HDTV Projection Television
TV Power Offs
Check these splitter RCA #205064, Q4101, U4101, C4102, C4118, C4108
Jan 07, 2008 | RCA P52937 52" Rear Projection Television
TV WILL NOT TURN ON
there are two
quick things you might be able to do. If it is a PTK195 you can most
likely install the updated power supply board. If you can solder and
know safety (like discharging caps) you can update the PS chip from an
STK730-??? to an STK730-180 (IIRC). I found that simply replacing the
chip with an equivalent fails most of the time. The 180s seem to hold
up.
Dec 16, 2007 | RCA P52939 52" Rear Projection Television
52 rear Projection RCA-Convergence auot cycle not working?
It's late but try unplugging TV from a/c outlet for 5 minutes,if no fix call factory authorized service center. Good Luck, God Bless.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
