It spins but the water doesnot come out - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 10, 2010
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Washer model gbvh5140
See if your hose is kinked behind washer, hope this helps
Aug 15, 2013 | Computers & Internet
The washer will not go into spin mode or drain the water
see this cause:
t spins, but doesn't pump
drain line is clogged,remove the large hose that connect to pump to bottom of outer tub remove the cloth with pliers, propeller pump damaged replace
It doesn't spin or pump
frozen pump pulley replace pump,check manual, if doesnot replace it
It pumps, but the water returns
drain hose if reache more 4inches, cut ot the remain.if lower install air/gap siphon break assembly.
God bless you
Jun 19, 2012 | Washing Machines
The display doesnot come and processer and powersupply fan also doesnot move?
If the fans do not "spin", nor even "rock" slightly, just once, when you connect the AC power-cable, or press the ON/OFF button, then it is the power-supply that needs to be replaced, at least temporarily, to "trouble-shoot" the problem.
Sep 09, 2010 | Intel DG31PR Motherboard
Water does not come to the washing chamber
Switch the machine on when the room is quiet
Dial up a cool wash hit the start button then listen while you remove the power you should hear water falling into the drum
If there is power to the fill valve ? then you need to put a meter across the terminals to check for resistance , no resistance means an open circuit coil and a the valve will not open
Jan 05, 2010 | Washing Machines
I got kenmore 70 series. it doesnot spin but it
You have a bad lid switch . This is the piece , the lid actuator piece , goes down onto , in the hole on the top . Try putting a screwdriver into the hole , to activate the switch , to drain the water and to spin the clothes dry enough to remove , until the switch can be replaced .
Nov 26, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
Kenmore 28731 top load washer
You will need to replace the motor coupling. Here is a video to show you how to do it.
Oct 24, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
