Question about Dacor Kitchen Ranges
First, how do I take apart the top section with the buttons, when the vent is in the down position, and nothing is working? Previously replace the buttons and the circuit board under them (myself) but they didn't line up properly because the vent is from 1990 and the new part is 2010. So I drilled some new holes in the board for the hubs on the button holder to fit, but it apparently wasn't the exact fit, as some of the lights go on, intermittently, but nothing goes up or down or sucks. So, first things first.....how do I get the vent to the raised position so I can take it apart for another go round? Thanks.
Rotu
  • 175 Answers
SOURCE: control buttons inconsistent
Usually the buttons themselves are the problem. The little contacts on them that connect the gold terminals on the board you replaced get dirty or wear out. If you are not getting any erratic operation (up and down on its own or locking itself in child lock etc. ) then I'd bet you just need a row of buttons to go with your new board. just as a note, the control boards down below are quite failure prone, so if you are getting any other weird operation, i would suspect that instead. they have redesigned the entire board to be more reliable, if that tells you anything. Hope this helps.
Posted on Jul 01, 2007
  • 1894 Answers
SOURCE: Dacor Oven Death
i think ur breaker is dead
Posted on May 15, 2008
  • 3 Answers
SOURCE: dacor goes up then right back down
one of the snorkel switches is bad if that not the problem i would then change the board but i would start with the switches on the snorkel motor
Posted on Jan 19, 2009
SOURCE: Dacor Raised Vent Buttons reply, sc58@aol.com
There are two small screws on the bottom of the top lip. Remove them and pull out the endcap inserts. The top shoudl then pull up with maybe some light force. Then you can get to all the bottons.
Posted on Jan 20, 2009
SOURCE: More button doesn't work, but less goes to 350 and under.
I have had this same problem, you have to remove the back of the unit on the control panel and push the board back into place. It is very sensitive and pops out easily. My most recent problem now is that the broiler is turning on by itself; be careful of this next issue. Not sure how to solve this yet!
Posted on Feb 22, 2009
Air blend door actuator
Possible bad blend door actuator .some gm cars can be relearned to the new climate control head
Jul 28, 2013 | 2001 Oldsmobile Aurora
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
I took my PS3 apart and now the wireless buttons won't work
Bend the sensirs up I lil yr the metal touch pieces towards u and put top bak on see if that helpd
Apr 22, 2012 | Sony PlayStation® 3 (60 GB) Console
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
Wont turn on... balck screen... when i hooked it up to my computer nothing happened... tried the lock button, power button, and the wheel... still nothing
Hi, I just learned here that you have to do TWO things to get it to turn on. One, make sure the slider is in the On position. Then press and hold the play button (top one on the wheel) for 3 seconds. Worked for me, when previously the only way I could get it to turn on was to hook it up to a power source (wall or USB), which sounds slightly different than you. Hope it works anyway!
Jan 02, 2010 | SanDisk Sansa Fuze MP3 Player
Disassembling the remote control of samsung le-26r73bd/xeu, some of the buttons seem not to be working anymore, so I need the manual to where the pins, which are holding it together are, so I won't brake...
Start at the fat end of the remote by inserting a thin flat screw driver between the grey and black edges of plastic. As you move down you'll feel the driver enage into a gap. At this point lever up the black plastic. Continue around the fat end of the remote releasing it from the catches, work yourself around until you reach the top end prying apart the catches of the remote. Now you can remove the two sections apart. <br /><br />To remove the keypad you'll need to pry another catch that holds the keypad down at the top near the IR diodes. TAKECARE not to damage/break the catch, it was a very thin piece of plastic in my remote and broke off when I tried to replace the key pad. In my case I used some tape to hold down the keypad inside the remote housing. Clean the PCB where is makes contact with the silicon keys and replace. Now replace the two sections of the remote alighning the catches which now snap together.
Jul 12, 2009 | Samsung LE-26A457 26 in. LCD TV
Tv shuts off automatically periodically
There is a switch located behind the lamp vent panel on the back of the set. Remove the vent panel and hold this switch in the down position while you turn the set on. The set should stay on as long as this switch is in the down position. If the set stays on, check the inside of the cover you just removed from the set. Locate where the switch rests against it and make sure that it is not broken. When you reinstall the vent cover, lay it flat against the back of the set and slide it down so it can catch the switch on the way down. Most times this switch will come loose and flip up while moving the set. Or if you just replaced a lamp and didn't get the switch back in the right position.
Feb 24, 2009 | Televison & Video
Refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Oct 01, 2007 | Kenmore 93361
Fridge freezer not cooling from new - buttons not working
Sounds like an air flow problem from the freezer section to the refer section. Check that nothing is blocking the air vents, and that the dampers are operating properly (they control the flow of air). Of course if it's under warranty... call the service techs out.
Oct 27, 2006 | AEG S75578KG Side by Side Refrigerator
Kitchen Ranges Logo
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
