Question about Dishwashers
Dishwsher is not draining water out.. - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Oct 10, 2010
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
My dishwsher will not drain always tried a bit of CLR then it would drain for a little bit.
Hello..
If the machine has an drain pump..remove it and check the impeller..can be broken if is a plastic made.
If the machine does not have a drain pump...the drain solenoid is bloked on close and the water is not draining.
You can check also the drain hose to see if is stoked somewhere.
Good luck
Jul 02, 2013 | Dishwashers
Dishwsher will not drain
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 02, 2011 | Dishwashers
Dishwsher wont drain. never happened before. do not use dishwasher very often.
I would first check where the drain hose from the dishwasher connects to the drain stub under the sink. Remove the hose from under the sink and place it into a bucket. Close the dishwasher door and cancel the cycle to put the dishwasher in a drain cycle. Listen for the drain pump to activate. If water comes out of the hose check the stub where the hose connects under the sink with a screw driver to make sure the spout is clear of debris. If no water comes out of the hose, empty the dishwasher by hand using a plastic cup and when empty remove the hose at the pump under the dishwasher and check to see if there is any debris at this point. Make sure hose is clear from the dishwasher pump to the drain stub under the sink. You will need to place a towel or two on the floor as water left in the bottom of the dishwasher will come out when you remove the hoses. If still no water comes out you may have to disassemble the bump assembly. Not knowing what make and model you have I can't help you past this point.
I hope this is of some help.
Jan 25, 2010 | Dishwashers
Why does the soap not melt or get distributed to the dishes?
Using too much soap is worse than not using enough. Over time, soap scum will build up and plug the internal plumbing of the dishwasher. Often, there is simply not enough water in the dishwsher to be effective. The GE uses an electric solonoid which opens when it is time to drain. This item can get corroded and allows water to pump out when it is supposed to be washing. Also, it is possible you are not getting enough water because of supply problems. Disconnect the hot water line and check the flow of water and also the intake screen to see if it is plugged. If you have ample water after the a wash cycle has been running for several minutes, check the water timeperature. It should be around 120 degerrs F.
Hope this helps, Ken
Jul 26, 2009 | GE Dishwashers
HI i have an electrolux dishlex dishwsher that is brand new and just installed. Ive used it a few times an dhave noticed that there is water at the bottom of the dishwasher, thats not draining, I thin
there is always a little water in all dishwashers. Sounds like to me that you may have a kinked drain hose or maybe the way you have hooked the drain up. The drain hose should go to a vacuum break that is mounted on the sink flange and then another hose goes to the disposal. If you have the hose hooked directly to the disposal you may be getting water back from the sink to the dw. raise the hose up as high as possible and attach under the sink so there is a high loop in your hose so water cannot drain back from the sink
May 29, 2009 | Dishwashers
Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Sep 23, 2007 | Bosch 24 in. SHE44C05UC Stainless Steel...
Dishwasher doesn't seem to pump water through
add more water to see if it is not filling enough. if it is there may be a problem with the wash pump either a blockage or it seizing.
Jul 24, 2006 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
