Question about Kinyo PS-160 Computer Speakers
Speakers just quit working not sure if it was any software i added it says it cant install them after they have already been working
    Sergeant:
  • 298 Answers
Try checking your connection or try the speakers on a different pc to ensure they are still working
Posted on Oct 10, 2010
How to install speakers
Most commonly computer speakers have a 3.5 mm jack plug that fits into the audio output of the computer motherboard or sound card if it has one. If this is the case there is no installation or software required.
Lots of modern computers have none of the traditional sockets and rely entirely on usb connections when usb speakers will be needed. It is possible some software could need installing before they will operate, though it is equally possible they will work straight away. It depends whether your operating system already has the necessary drivers.
If usb speakers arrive with a software disc you have the option of installing manually or allowing the setup wizard to install it for you. Both ways might work or only one way.
Feb 05, 2016 | Audio Players & Recorders
I recently had to reformat my computer, and I don't have the software to reinstall the logitech program or whatever. Is there any way to get these working? the sound card is already installed in the...
Follow the procedure for speaker installation here. Verify it.
As this is a very basic output device, it uses the computer's Audio drivers to channel the sound from each speaker correctly. Make sure that your audio driver is installed and working. Other wise open another ticket and give us info on the sound card
Sep 02, 2009 | Logitech X-530 Computer Speakers
Monitor speakers not working
You need to reinstall the software driver for the sound card. Usually, a virus/mal/ad/spy-ware will disable sound quite readily!
gurutim
Mar 21, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Adding 2 speakers to x-240 kit
Sure It will work, doing it that way 2 speakers will be left, 2 will be right and your sub will just play the deep sounds from one or both channels.
Jan 10, 2009 | Logitech X-240 Computer Speakers
I have a compaq computer and two external speakers which quit working. where do the wires for the speakers atach
Normally the lead which has a plug the same as a headphones plug goes into the green socket on the back or sometimes the front of the PC. The speakers should then already be joined together or have a lead that plugs one into the other.
Nov 19, 2008 | Computers & Internet
Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
Lost my software disc to my speakers
You dont need software for your speakers, you need software for your sound card. Should already be loaded on your computer unless someone added a sound card..Go to the card manufacture for the driver..
Sep 23, 2008 | Logitech X-530 Computer Speakers
I have installed windows xp and cant get any sound out of my speakers. my speakers are not the problem
check the 'adjust audio properties' in the hidden icons. its the 1 with the little speaker next 2 the clock if dint already no.
Jun 26, 2008 | Computers & Internet
Firewave not recognized
The solution I found which seems to work is to go into Activity Monitor, and quit "coreaudiod". This forces it to restart and rescan for audio stuffs which makes it work.
Mar 29, 2008 | Griffin Technology FireWave Surround Sound...
Kinyo PS-160 Computer Speakers Logo
53 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
