Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
New Printer will not go past "Please wait..."
Followed first time use directions by taking off orange tape, installing print head, ink, etc. Turn on and menu display asks for "langauage" & "country". After answering that, all I see on the display is "Please wait..." with a blinking green on/off light. Turning off and on again and now get a "paper jam" message. I check trays and all appears to be OK. Press OK and just get the wait msg. Done this numerous times. This is straight out of the box.
  • Ronsh123 Jun 10, 2008
    That was the issue. My wife actually did just that - removed ink and the print head and applied more pressure to insure the print head was seated properly. Originally, I did not want to apply too much pressure and I thought I heard it click into place. Obviously not. The error message threw me off though with the "paper jam" statement.
    Is the firmware upgrade necessary? The printer is working fine now and I'd hate to have something go wrong now? What's in the upgrade?
    Thanks.
  • 34 Answers
What you need to do is to remove the inks and the printhead again and then install it. You just put the printhead improperly. Then once you have cleared the error connect it to your computer and upgrade the firmware by going to www.kodak.com/go/downloads
Posted on Jun 09, 2008
  • mark manuel
    mark manuel Jun 15, 2008
    First check if you are using the most updated firmware by printing a diagnostic sheet then go to the website to check if it will match. If you are using the most update firmware and the printer works fine now then no need to upgrade the firmware.. upgrade basically enhances the performance of your printer.
    Cheers
Dont know how to replace printercartridges in mx700
Install the print head or ink tanks properly following the procedure If reseating or reinstalling to clear an error, the ink tanks and print head must first be removed.1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.Note: When the top cover is opened more than ten minutes, the print head moves to the right side.If this occurs, close the top cover, and open it again.2. Open the paper output tray.Note: When installing the print head, roceed to step 3.When installing the ink tanks, proceed to step 6.3. Raise the print head lock lever.4. Pull out the print head from its package, then remove the orange protective cap from it.Note: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>.Doing so may cause printing problems 5. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.6. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.7. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.Note: - Do not touch the ink tank contact <1>. Doing so may occur printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
8. Insert ink tanks into the print head.1) Insert the ink tank into the Print Head.(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.(3) Ensure that the ink tank lamp lights red.Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes. On: The printer is ready to print. Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank. Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.- Off: An error has occurred and the printer is not ready to print.10. Close the top cover.Note: When starting printing next time, the print head cleaning launches automatically.During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
Sep 20, 2011 | Office Equipment & Supplies
Ink tank
Greetings,
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Canon MP830 All-In-One Printer
My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
Solution: Install the print head and ink tanks correctly iP3000 / i560
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
    Improperly installed:
    <Left Image> The M ink tank is not fully seated.
    <Right Image> All ink tanks are not fully seated.
Dec 03, 2010 | Canon PIXMA iP1300 Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Installation of the cartridge for Canon Pixma iP1600 printer
To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
cartthingsnottotouch.jpg3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
ip1600puttinginink.gif4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Jan 06, 2009 | Canon PIXMA iP1600 Printer
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Ink module will not center itself
  1. Confirm that the printer is powered on and press the <Open> button (MP500) or manually pull open the paper output tray
    NOTE: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  4. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    <5> Tape remains.
  5. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    CAUTION: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    NOTE: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note : MP500 shown.
    NOTE: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    CAUTION: When closing the scanning unit (printer cover), be careful not to jam fingers.
    Memo: The next printing begins, the print head cleaning will begin automatically.
Mar 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
    <5> Tape remains.
    N
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Getting error 681 "more thn one magenta tank instaleld" on MP530
    <5> Tape remains.
    N
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
111 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
