Question about HP dvd740i DVD±RW Dual Layer Burner
Hp dvd740 doesn't read any blank discs..
My Hpdvd 740 won't read any blank discs when I try to burn. It continues to say its empty. I've tried different kinds of discs and they're all doing it. Yesterday it started to burn, then quit and said it couldn't find disc. help!
  • happyday19 May 31, 2008
    Thanks, I will try that, and letcha know
    Novelist:
    Champion:
  • 236 Answers
You're starting to experince laser pick up failure, maybe starting to weakened. Try using a cleaner first and it could be dirty nor with carbon deposits. If still the same then i dont know of any shop repairing DVD drives, it will be up for replacement only.
Posted on May 31, 2008
Target disc not empty
Target disc ( this is what you've selected to burn TO) is not empty(is not a blank disc). You should try a different blank disk, or else you have your source and destination backwards.
Nov 16, 2012 | Acard Technology (ARS-2030LD) DVD±RW...
Hi! I inserted a burned dvd r into my Mac but it's not reading it. The message You've inserted a blank CD pops out. I tried using a PC but it can't open it either, it says there's an error...
there are a few reasons why
1.) the formatting of the disk may be formatter for a PC and NOT a MAC
2.) after burning, this dvd was never "closed"
3.) You burned a coaster
good luck
Jun 06, 2011 | Computers & Internet
My HP DVD 740 won't recognize blank CDs
Sounds like the lens is dirty. Run a cd cleaner through the drive. That should take care of it.
Dec 15, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Blank DvD Disc Reading Problem
Goto HP's website to the support section download the drivers and replace your current ones. If it still does not the drive has failed and needs replacement.
Thanks Frank Z.
http://www.codebluehelp.co.cc
3868607368
Jun 29, 2009 | Computers & Internet
LG HL-DT-ST DVDRAM T10N ATA DRIVE
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc. Also, on PCs, verify that the temporary file storage area on the hard drive used by the burning software has enough free, defragmented space. Allocate at least 5GB for a DVD (9GB for a double-layer [DL] disc) and about 1GB for CD burning.
Feb 28, 2008 | HP Pavilion dv6000z Notebook
Won't burn CD-r or DVD-R
make sure that your program that is setup to record. i.e nero-img burn et,c. is set to look at the drive D:- Or E:- whichever letter your drive is assigned by the computer.
Also try using a different Blank-media. if any disk has failed a full write, without finalizing Or creating the Table Of Contents. It will read as Empty Or Blank. you can see This By looking carefully at the underside of the Disk, to see whether it has been burned by the laset. ( Towards The Centre ) if the Dye is darker on the inner-edge, then this is possible.
You can also try using a different Packet writing software, or re-install the program.
Hope this helps.
Mike @ Compurepair.
Feb 22, 2008 | Sony DRX-710UL DVD±RW Dual Layer...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Disc will not play or record message disc empty disk full
did you try a dvd movie do they play if so buy a different brand of blank dvd this happened to me i use
dvdr= sony ok
retail plus ok wal-mart brand
imation ok
at&t nogood on the rca machine
dvdrw= dataware ok
imation ok
cdr =tdk ok
these are all the brands a know are working on rca machines!
but keep in mind you can buy the most expensive blanks and they may or may not work on different machines
Dec 04, 2007 | RCA DRC8052N DVD Recorder
Drive problems
Try cleaning the head, if that dont work reinstall drivers
Nov 15, 2007 | E-Machines eMachines Desktop PC
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
HP dvd740i DVD±RW Dual Layer Burner Logo
246 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
