Question about Gateway FPD2275W LCD Monitor
I have a Gateway FPD2275W lcd hd display monitor, and when ever i goto turn on my computer my monitor works for a couple of seconds then blacks out, it doesn't turn off, the screen just goes black. i have tried the monitor with a different computer and VGA cable so i have concluded it must be the monitor that isn't working. please help me fix this.
  • 11,361 Answers
First warning, the cable attached to the front panel is really short and you can easily break it.
Look for bad caps as shown here:
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 10, 2010
Gateway FPD2275W LCD monitor lost "Red" signal of RGB display
Not really, first check your connections, normally when you loose red a pin broke off the VGA connector.
If the panel died then its probably not worth while. The red panel is however, under the most stress.
Jul 09, 2010 | Gateway FPD2275W LCD Monitor
The Gateway FPD2275W TFT LCD Monitor the screen is black when my computer is up & running. I can briefly bring up the screen, and it shows my desk top, then changes to black. I have been trying to...
Hi!
The problem is not the setting on your monitor...The problem is the backlight inverter located inside the upper and lower edge of your screen..
It is busted. The backlight inverter is the light source responsible for the displaying image on your screen. If these were busted.. then the only thing you will see is black screen.
It is very risky for you to replace it by yourself if you don't have the knowledge and the right tools to open the back of your lcd..My suggestion is to bring your monitor to a credible technician to have your backlight inverter replace. if there is warranty for your lcd, please avail this.
Hope it help..
Much appreciated if you rate this solution..thanks..
May 26, 2010 | Gateway FPD2275W LCD Monitor
GATEWAY FPD2275W 22" will show everything when unhooked from pc then reconnected but within seconds goes to a black screen. I have 2 and the other one works fine so it is definitely the monitor giving the...
Chances are that some capacitors in the power supply have failed. some monitors are known for this. The parts are readily available, but they do solder in.
Nov 13, 2009 | Gateway FPD2275W LCD Monitor
My monitor fpd2275w gateway turns on but the screen is black
mine does it too...it seems to be that the back light is not staying on...seems to come on full brightness for about 3 seconds then goes out, there are images...but no backlight
Aug 27, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
FPD2275W LCD Monitor power on blinks the display words- gos black
I don't think you will be able to match that IC without an ID number
Jan 20, 2009 | Gateway FPD2275W LCD Monitor
Monitor problem
You need to figure out if the monitor is faulty or if it is due to the power in your house (not likely) or the fault of the computer.
  1. Try the monitor on other power jacks.
  2. Try the computer on other monitors and see if you get the same response.
If it seems to just be the monitor then you will most likely have to have it serviced or replaced. Is it still under warranty?
May 13, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
154 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
