Replaced the theromstat in the hall and now the unit won't come on at all. What would be the problem?
  • 1,420 Answers
If you did not turn power off to heating system prior to the replacement, you may have blown a fuse in the heating system. i need a make and model number to help you further.
Posted on Oct 11, 2010
LE error (checked stator and replaced HAll sensor already)
If the control board does not receive the input it will not operate does the door lock? However:
The attachment shows how to diagnose and repair a failed hall sensor, the usual cause of
an LE error code.
DO NOT replace the stator until the hall sensor has been tested. 98% of LE error codes are
caused by failed hall sensors.
[DD motor SVC check process ]
Pre Check
1) Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for
smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the
drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
2) Don't replace the PCB when the hall sensor is replaced.
Check the hall sensor as shown in the new process.
O have a file I can send but can not upload here if you want it, contact me melissamaemartin@yahoo.com please put hall sensor in subject line. Thanks
Mar 28, 2014 | LG WM-2277HW Front Load Washer
LE error drum won't spin.. replaced hall sensor and harnesses
look under the unit and see if the transmission solenoids are working..a wire may have dropped off..
Jan 12, 2014 | LG WM-2277HW Front Load Washer
Where is the serial number found on a 1999 cabrio distributor?
There was only one distributor number used by VW for all 1999 Cabrios (US market), all references below are for US models only. (for Canadian market there were some different ones). The VW part number is 037 905 205 T, these were made by Bosch. Bosch did possibly supply a some different numbers to VW (Bosch number 0 235 520 066 replaced by 0 235 520 065) but both had the same VW part number and used the same repair parts. There is no serial number for the distributors, just part numbers. The original distributor will have the VW number as well as one of the Bosch part numbers stamped into the body of the distributor. The distributors rarely had to be replaced, as most parts to repair them are available. The ignition hall unit (sensor) is replaceable in the 037 905 205 T distributor. I am a independent parts distributor for VW and Audi vehicles and also a Bosch warehouse distributor. I have the hall unit in stock for this distributor, mail order price is $121.70 + shipping (and + sales tax if shipped within Alabama). I can also install the hall unit in your distributor (if needed) if you send me your original distributor. To replace the hall unit the distributor has to be disassembled and if done improperly the distributor can be made unusable. Call me or Email me if you need more information. 1888VWPARTS vwparts@bellsouth.net
Nov 27, 2012 | 1999 Volkswagen Cabrio
Dishwasher DD605 f2problem motor has been replaced
Hi.
F2 means "Motor rotation not sensed". If the motor has already been replaced , then either the hall sensor that detects the rotation is not working, the rotor is jammed, the control board is defective, or there is a wiring problem.
• Foreign object has jammed the rotor.
• The rotor has failed.
• Hall sensor connector or wiring fault at hall sensor or controller.
• The hall sensor has failed.
• Motor stator winding or connection open circuit.
• The electronic controller has failed.
• PCB mains filter has failed.
Feb 05, 2012 | Fisher and Paykel Dishwashers
LG frontloader runs thru majority cycle & towards the end it stops & flashes "LE" code. I have replaced Hall sensor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error, but it is possible to separate the working from the non-working, just by following a process. The reason this particular unit has been on the injured list for so long is the first tech never followed a trouble shooting process to ensure the parts being replaced had actually failed.
Nov 26, 2010 | LG WM-1832C Front Load Washer
I got an E3 flashing, what does that mean. The
Okay; This will essentially be a Hall Sensor fault. The Error code (E3) Is issued when the Motor control board is attempting to drive the motor (during the spin out), but is not seeing any tachometer response readings. The Hall sensor monitors such movements to relay the necessary rotation information to the Motor control board. When the Hall malfunctions, the MCB will assume that the motor is "locked" and it will issue the (E3) code.
The necessary actions are to replace the Hall sensor. Here is a picture of the Stator(Motor) and Hall sensor.
Click here to access the service/repair manual for your unit. This manual will help you disassemble the affected area. You will first need to remove the rear access panel, before gaining access to the affected section. Once the rear panel is removed, focus on page 33-34 to help with removing the stator so that you can replace the damaged hall sensor. Please allow time for the manual to download, due to its size.
  • Once you have replaced the defective Hall sensor, the unit will return to its normal operating status.
Jul 25, 2010 | Maytag Washing Machines
We have an air make up unit on our community hall with no heat
Depending on the outdoor temps, 10 kw won't heat much. If you have a multi-meter you can check the amp draw as well. You should get 20 amps for each heat strip. Each heat strip is 5kw.
Mar 23, 2010 | GE Built-In Room Air Heat Cool Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
