Question about Whirlpool GU2400XTP Built-in Dishwasher
No water in top shelf - Whirlpool GU2400XTP Built-in Dishwasher
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 10, 2010
Why is it leaking water onto top shelf
Most modern fridges have an automatic defrost that works by draining into a sort of funnel above the back of the top shelf.
The funnel is connected through the back of the fridge to a rubber drain tube that goes down the outside of the back to a heated evaporation tray under the fridge,
The hose and/or funnel can get clogged with disgusting yucky stuff, and the water spills over the top of the funnel onto the top shelf.
The fix is to clean all the bits. It's usually no big deal to take apart.
I have resorted to blowing through the tube from the bottom end and then cleaning up the mess, and brushing my teeth. Quite revolting but, that's the price I paid to become an expert.
Cheerfuls
Nov 20, 2015 | Refrigerators
How do I reset fridge model #106.51132210 it drips water from top and freezes on top shelf of fridge side
I'm not sure if resetting will help, but the easiest way is to just flip the breaker off and then back on.
Dec 04, 2014 | Refrigerators
Why is there water on top shelf in fridge
I would guess the fridge is not set level. A small amount of water is normally meant to condense and run down the back of the fridge and then evaporate outside the fridge.
If either the fridge is leaning forward slightly or if anything on the top shelf is touching the back of the fridge, then instead of running down the back of the fridge water may instead end up on the top shelf.
Assuming the fridge is still working in every other respect then this is what I would suspect.
Aug 25, 2014 | Max-Fridge Refrigerators
Items on top shelf are not getting clean whereas bottom shelf dishes are clean
I had this problem, and on mine it was because when I pushed the top shelf in , the little sleeve for the spinning nozzle wasn't fitting over the coupling that supplies water to it. Try checking the alignment when you push in the top shelf.
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Oct 19, 2009 | Dishwashers
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water not going to top shelf in dishwasher
Have you tried cleaning out holes in top rotor, especially the end ones?
Jan 26, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Top shelf not getting clean
It sounds like the hose at the rear of the top shelf has come unconnected. Pull the top shelf out when the washer is empty and take a look. If the hose has come apart you should be able to push it back together. Good luck with it.
Dec 27, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Whirlpool GU2400XTP Built-in Dishwasher Logo
41 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
