Question about Toshiba CZ36V51 36" TV
Toshiba CZ36V51 picture problem
My TV was working good till a few months ago then it went from a 36" screen down to a 2" horizontal line in the middle of the screen. it would go back to normal for a while but it needed a bump on the sides and now nothing brings it back. how can i repair it my self?
  • Pinoy Eric May 31, 2008
    thank you for the suggestion. i found the board on the back of the tube was loose. i pushed it in and it brought most of the screen back. how can i get it to hold tight? thanks again.
  • piggie71 Oct 18, 2008
    I have the same problem with my picture, but now there is no picture. How can we fix it?
    Thank you
    Novelist:
    Champion:
  • 236 Answers
Sir, if you are not a technical person what i mean does not really repair like this equipmetns then it will not be easy for you to repair this. but ill give you an idea of what's wrong with your TV. Just cold solder or loosened solder on the vertical amplfier section. But if you can handle soldering and also dismantling the main board then you can just try to find the vertical amp section and look at those solders of parts around for loosened welds. just resolder it. be careful not to short any part or it cause major trouble and make your problem bigger. For a technical person, this trouble is a simple one.
Posted on May 31, 2008
  • Redentor Rivera May 31, 2008
    it can't be that board bro, probably the cabling of that board got pulled the other end from the main board. still it is the vertical amp that is the trouble and you need to have all the parts resoldered, or look for loosened solder from that section
Hello! The picture on my toshiba cz36v51 is halved vertically, and has a duplicate picture on either side. Is that fixable? This problem occurs when trying to watch movies, cable, xbox...etc. Fixable or...
Sounds like you have a horizontal timing error causing the mirrored image. It is fixable but would require the main board to be replaced. The part number is 23783078 but appears to be no longer available.
Aug 28, 2010 | Toshiba CZ36V51 36" TV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
teranco@hotmail.com
Jul 13, 2008 | Toshiba 32A40 32" TV
Problem with tv
Could be a horizontal output fault, faulty power supply, a simple dry solder joint or HVT. If you can hear arcing or smell an ozone odour, it will be the HVT which may cost a bit.
Without knowing the actual cause, it's impossible to say how much it would cost to fix it.... could be anywhere from $50 to $250 etc
Best to have it checked by a technician and get a quote to repair... then decide if you think it's worth it.
Toshiba is generally a reliable brand, so if you were happy with the picture quality before the fault occurred, it's probably worth repairing.
Cheers
Jan 05, 2008 | Toshiba 36A41 36" TV
Toshiba 36A50 Horizontal Line
Ok, The vertical Ic is IC301 Ta8427K And Capacitors around IC chroma 2.2 uf 50 volts. You will see small red capacitor ( with C302....4 or 5 ) reference. Replaced others capacitors on vertical section 220 uf 35 V or 100uf 35V. I hope this can help you. Or if do you have any picture chasis, send to me and I will show you where are the problem., Thank you
Dec 12, 2007 | Toshiba 36A50 36" TV
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Toshiba CZ36V51 36" TV Logo
189 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
