Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
The bowl does not fill - there is only a little water in the hole leading out of the bowl. This is an issue for efficiency and cleanliness.
  • 70 Answers
You need to replace the ballcock.
Posted on Oct 27, 2010
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Not enough water goes into the Toilet Bowl, The Tank fills up fine but very little goes into the Tank, Terrible Flush
THERE ARE LOTS OF SMALL HOLES WHERE THE WATER COMES OUT OF IN THE RIM OF THE TOILET BOWL, SOME TIMES HARD WATER BLOCKES THES AND THEY NEED TO BE CLEANED. THEY CAN BE CLEANED USING A LARGE SEWING NEEDLE, PUSHING IT INTO THE HOLE UNTIL IT FEELS A BIT BIGGER, YOU WON'T DO DAMAGE AS IT IS VERY HARD METERIAL. a
AFTERWARDS TURN OFF THE WATER, AND LIFT THE VALVE AT THE BOTTOM OF THE TANK AND PUT SOME TOILET ACID INTO IT. THIS WILL ALSO HELP CLEAN THE HOLES.
May 22, 2012 | Kohler Toilet - One Piece with Ingenium...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
The water level in the toilet bowl is too low. Can I adjust the level, and if so, how?
Too little water in the toilet bowl to start with may be due to a lost or mis-connected fill tube that directs some water into the toilet tank standpipe (and thus into the bowl below), while the toilet tank is being re-filled. Check for that little tube.
Check the web site out below for more information on this topic.
http://www.inspectapedia.com/plumbing/Toilet_Slow_Flush.htm
May 23, 2010 | Jacuzzi Maxima DP55959 White Toilet Bowl...
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
Toilet bowl doesn't hold water but tank is full
The bowl is filled up with the little hose inside the tank, it locks inside of the overflow drain. And runs water in there as it flushes to swirl the water and fill the bowl. Water seeks it's own level, and the level in the bowl is at the top of the trap. It has to hold water, unless it isn't filling or it is leaking. Check out the filler and hope the bowl doesn't have a crack in it. Hope this helps.
May 03, 2010 | American Standard Home
Honda cr125 idle issues, wont idle not sure whats going on????
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side or a plug on the bottom of the carb float bowl. Remove the screw/plug then replace it after the fuel drains. Remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well. The diagram below depicts the problem area. The bike will idle properly once the pilot jet and related passageways are cleared.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
Please rate this solution. Thanks!
Aug 08, 2009 | Honda CR 125 R Motorcycles
Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Aug 01, 2009 | Kohler Home
Replaced toilet fill valve - now bowl water level a bit lower
First off,If the air vent was clogged the toilet would back up and overflow and when it did flush, it would make a gurgling sound.
secondly the water level in the bowl is not important as long as it covers the opening,The water is only there to keep out sewer gases so they don't enter your home and the shape of the trap will always maintain the proper amount of water needed to prevent this.
The previous water level may have been due to a partial clog that has since been removed.
Jul 26, 2009 | Home
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
254 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
