Question about Honda Pressure Washer PSI 3000
I have a Honda 11.0 HP pressure washer 3000# ,how do I remove the pump from the engine?
  • 2,841 Answers
Remove the bolts holding the pump to the engine. Turn the engine over to align the hole on the flange with the set screw inside holding the pump to the crankshaft. Loosen the set screw fully which is more than likely an allen screw. Now remove the pump from the engine. You may have to pry with a screwdriver to get it loose. If it still will not come off there are special holes that you can use to thread into these holes near the mounting holes to press the pump off. Just tighten them alternating back and forth until they push the pump off the crankshaft. Your pump may be slightly different depending on make.
Posted on Oct 11, 2010
5 Suggested Answers
  • 1388 Answers
SOURCE: pressure washer, john deere 3000 psi, honda engine
Pressure variance is caused by the unloader/pressure regulator valve or slipping belt on belt drive systems. Worn packings in the unloader will not maintain pressure. Try lowering the pressure to 1000 psi then slowly increase until problem reveals then lower pressure again to maintain steady stream. This problem can also develop if the wrong size tip is used in the gun. Example, if output rating is 3000 psi at 4.5 gal per min and you are using a tip for 3000 psi at 4 gpm. The unloader will release causing variance of pressure. Easy way to lower pressure of system is to increase the size of the tip to 5 or 5.5 gpm in a system rated at 4.5 gpm. Enjoy
Posted on Dec 02, 2008
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
  • 68 Answers
SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Posted on Feb 08, 2010
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
I have a Honda GX340 power washer and would like to know what types of oil and quantities I need for the engine and pump
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Honda Pressure Washer PSI 3000
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
Feb 05, 2010 | Honda Maxus Prosumer MX5223 Pressure...
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
I have a 3000 PSI Honda pressure washer. The motor
May have sediment buildup in the pump housing, ???
Jun 04, 2009 | Honda Pressure Washer PSI 3000
Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Jun 01, 2009 | Honda Pressure Washer PSI 3000
Honda water pump
normally all the water pumps coupled with portable gas powered engine have 3000 - 3600 rpm
May 19, 2009 | Honda 8 HP Engine
Honda Pressure Washer PSI 3000 Logo
64 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
