Go to options in the menu scroll down to the bottom and select factory reset follow onscreen instructions and this will clear the faultPress OK then Menu on remote
You can't post conmments that contain an email address.
www.fixya.com/support/t17213833-error_ce60_e_studio_2820 Mar 19, 2013 - So I put in the code 8 clear/stop so it will show the error code. No error code is popping up. The number 8 just stays on the screen, like nothing ...
What is the error code? most error codes are the resault of a failed componenet, but on occasion disconnecting the power will rest the washers electronic control panel.
E0 error - ensure pot or pan is placed correctly E1 error - the circuit has malfunctioned E2 error - the temperature sensor is opening circuit or short circuit E3 error - the voltage is higher (140 - 160V) for 3 seconds E4 error - the voltage is lower (80 - 100V) for 3 seconds E5 error - the cooktop surface temperature is too high E6 error - Internal electronic temperature is higher than normal for 3 seconds E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Sometimes the convergence IC's failing will cause this. Also, the coolant for the picture tube can leak onto the circuit boards causing damage. Need to have it looked at asap as the coolant problem gets continuously worse.
I had the same problem with my C643 I took it apart and still found nothing wrong. I didn't feel like paying kodak prices so I just sold it on ebay so someone could get it for the high demand LCD screen.
