Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer FH code "sometimes"
This washer is nuts. ALL THE CHECKS ON THE LIST HAVE BEEN PREFORMED SO DON'T POST THE LIST AS A SOLUTION BECAUSE IT'S NOT!!! Washer may do 20 or 30 loads with no problem then BOOM here comes the "fh" again. Reset, and then fine for several loads or many loads . All components, connections, hoses and tubes on the list have been checked, cleaned, dianostics have been run and everything passes. Please give me a solution that is helpfull.
  • 3 more comments
  • jh4uk Jun 02, 2008
    YES.. all items on the check list have been preformed! No water restriction anywhere, and also note that no low pressure during wash times. Note #2 MC was replaced 6 months ago and problem went away till 2 weeks ago.
  • Anonymous Aug 10, 2008
    yeah some times 2 loads sometimes 3 loads then about 5 minutes in fh code flashes I checked everything, then it starts to drain
  • wildturkey19 Aug 15, 2008
    I have the same problem!!! Resetting is a joke. I've never had such a peice of **** in my life. Every six months it's something electrical. Six months ago F11 kept coming up. They said they had to replace the door latch, CCU, and interface. That was $250.00 later without labor. Now it's the FH code. We had low pressure coming into the house from remodeling but now we don't so resetting it should've done the trick. I called whirlpool and all they said was they could refer some technicians in our area to fix it.
  • J Kelsey Nov 17, 2008
    The dreaded FH11 code is coming up again. Does someone have a copy of the service manual so I can start working through fixes
  • Ajaxon Nov 17, 2008
    I had same FH problem today. It went away after I removed the "grit" that had obstructed about 40% of the cold water input screen where the hose screws onto the back of the machine. I assumed that was why the "downey softener" was not washing fully out of the input drawer and the detergent was. This all started after my well pumped dry and flushed a bunch of grit into the machine. (as evidenced by a very dirty detergent drawer). Reset of FH and unlock of door was biggest problem. I had to push Pause cancel button with control on button for about a minute straight. I dont have list of error codes or manual either.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Will this help in any way F/H error code in duet washer
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then
valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has
detected 10.5 gallons of water passing through it, but has not detected the pressure
switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Posted on Nov 17, 2008
  • 770 Answers
Have you cleaned out the small screens in the water solenoids in the back of the unit where the fill hoses connect?? Also this can happen in certian times when water pressure is low going into the unit or home
Posted on May 31, 2008
  • Gary Davd
    Gary Davd Jun 03, 2008
    Well i was going to email you the service manual but it sounds like you have done everything to fix it it sure seems like you have missed something but good luck with the repair and Thanks for the rating. I think it is time to call a professional
  • Gary Davd
    Gary Davd Aug 03, 2008
    flow meter
I have a 6mos. old Duet Sport Washer in a vacation home. Was working great! Then one day, not so much. Would "start" by sitting, then water would come in for 20 secs. sit... sit... 2 minutes later more water, may spin a little, sit.... sit.... After about 5 minutes, it would just shut off!
Had A&E come out. Replaced water sensor. Nothing. Replaced 2 control boards. Nothing. On 4th visit, the guy claims it is my home wiring (not covered under warranty after 30 days!) Had an electrician out but found nothing wrong.
Well.... I had an epiphany today and will test this Monday when I have time...
We installed a Geothermal System and updated our 20-y.o. electrical box. When the Geothermal system is running, the water pressure is lower (not significantly) but I am wondering if it is enough to cause the washer to shut down? If that is the issue, I will gladly do laundry when not running system if I know it will work reliably otherwise. I just wanted to share this for those who may also have similar issue. I will try to post my findings...
Posted on Dec 27, 2009
    Problem Solver:
  • 8 Answers
If I hadn't been fixing stuff myself, I'm sure the added labor would've driven this machine to 2 or 3 times the resale price. Used to be intermittent FH, never knew when it tripped. Now it is so regular, I watched the cycle and it appeared to be getting too much water before tripping. Since the pressure switch is so cheap and easy to replace, it only makes sense to replace it first.
Posted on Feb 04, 2013
  • Donato Feb 04, 2013
Whirlpoll washer displays F/H
Posted on Aug 14, 2009
How can I fix my whirlpool duet washer control panel it is stuck on control locked and I have held the button down and unplugged the machine-I hate this duet washer can someone help me? Tx, Laura
Posted on Oct 26, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
well..based on what you're stating here..sounds more like a sensor, based on the duty cycle.
Jun 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, or it reduces the cold water to a trickle, which sometimes causes the washer to throw an FH code. It does not h
Hi. Got some info about the FH error from Whirlool service manual.
F/H
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
In my experience the CCU is the problem (control board).
IF the machine has water! If not, check water valve, hose, water tap.
Do it overfill? If thats the case, the pressure switch is gone, its hose has a leak.
Hope this helps you
Sep 27, 2014 | Whirlpool GHW9400 Duet Washer
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FH Error code Whirlpool Front load washer. I
the only thing you can do is to go to the manufactures website and download the user manual and check the trouble shooting guide for a possible cause for this problem eric
Jan 17, 2018 | Whirlpool Duet GHW9150P Front Load Washer
Light is blinking FH
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FH?
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
3,946 people viewed this question
Dan Webster
Dan Webster
Sal De
