Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Good day, i have a animal - THERE IS LITTLE TO NO SUCTION - I HAVE CLEANED EVERYTHING. It appears as if there is some carpet rope in the holes of the main unit - entitles level 3 root cyclone. How do I DISSASEMBLE THIS - I BELIEVE IT IS PLUGGED WITH DOG HAIR. THANK YOU, JONATHAN
  • 377 Answers
Two things you can do: 1- Remove the beater brush and clean as best you can, taking out all foreign matter. Add some WD40 to the end pieces of the brush making sure the brush moves freely. 2- Since you have the beater brush out, probably a good idea to change the drive belt.
If you find this solution to be of help, I would appreciate a Thumbs Up. Paul
Posted on Oct 10, 2010
Carpet suction is not working
There are several filters that either need to be cleaned or replaced. Most forget about the filter under the canister. That is the main one for floor suction. More than likely it is clogged and needs to be replaced. http://youtu.be/RCRdUCBobIc
Oct 11, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
My dyson hose sucks good but, when i put handle down, it won't **** but brush does turn
I just had the same problem....suction from wand, but no suction from soleplate, the brush bar spins. Did all the troubleshooting steps on dyson.com but they didn't work...dyson.com says need to take to repairman, being a diyer I went to search engine. I didn't find a fix, however I found one myself....it appears the vac can get stuck in floor mode or in between modes....the dial on top on dc07 ....selector of floor or carpet..try pushing it back and forth to see if that puts it in carpet mode...check for suction or try vacuuming...if that doesn't work, looking at vac from behind vac on the right hand side is the selector dial..on top of bottom portion of vac.....with vac in upright position, recline it as if about to vacuumn floor...look down at selector area ...you should be able to see a rectangular type button exposed ..push this to reset position...you may have to push it a few times...then try vacuumniing.....I finally had suction from soleplate!! Another tipoff to this problem is my selector dial would not stay in place would pop I to carpet by itself, but only halfway....fro a long time my vac would work but not very well...had to go over same area.4-5 times..What a workout! The first time I contacted dyson via tele the rep had me remove some stuff and I was able to look at area below selector...what I saw was two holes, one hole was only over the other hole half way...hence at that time I had only part suction since holes were not aligning properly....I read somewhere as a further tip to get suction to engage, while vac is reclined step on front edge of vac head it said you'll get more suction that way, I haven't tried that, but thought it may help someone
Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Not picking up fuzz
I've had a similar problem with my DC07 Animal, although there WAS suction and the machine seemed in otherwise good condition, the vacuum seemed to be working normally, yet very little was vacuumed up. I would go over and over sections of carpet and get very little debris in the container. In my case, the cleaning brush roller bar was competely covered in debris (hair, dirt, string, stuffing from our chewed up dog toys, etc.). I removed the bottom cover and manually removed all this debris from the cleaner/brush roller, reattached the cover and it worked like new with great suction.
Apr 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Way too much suction
Did you call Dyson?  Just call their customer service and see if there have been other complaints like yours.  I just got the same model and will be looking out for this.
Randy
Dec 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brush wont turn
Make sure that the carpet selector is on carpet setting not bare floor. It only spins on carpet setting. If carpet setting is engaged and still doesn't work you need a new clutch assembly.
Oct 12, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Not cleaning as good as it used to
This vac. has alot of removeable covers, make sure that none has a clog and also that they are reinstalled correctly leaving no gaps. Does air blow thru the filter? Even after cleaning, if air can't pass thru, then they will restrict suction. Also is the brush roll turning, if not, then it would seem like there is not enough suction.
Jan 14, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bar does not run... Has power/suction?
Hi.
Check control knob on front left side is in drive or (D) when vacuuming carpet.
http://dc07.atspace.com/
Chris..
Dec 03, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
88 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
