Question about Vizio VO370M LCD TV
Occasionally when turning on my Vizio VO370M the screen is very dark. If I turn it off and then on again it seems to be okay. Seldom happens when it has been on for a while.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Hope you already know that this cannot be corrected through the MENU options. To resolve this issue you'll have to open the back of the unit and check the inverter board which is the power supply source for the backlights. The issue can be a bad inverter board and/or the inverter board is not getting 20vdc from the power supply maybe due to the connector that has gone bad/loose.All this is only recommended to be done by someone who has electrical expertise and knows about the internal circuitry of the unit. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 10, 2010
Vizio E480i-b2 LED TV loosing picture and sometimes shutting off
I don't think you had backlight issues like you thought you did as the set should have shut down the backlights totally as soon as it sensed over voltage or over current, I'd try a new main board and see if that fixes things up for you
Dec 09, 2017 | Vizio Televison & Video
Vizio vo370m has horz.,lines how do i fix
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 14, 2015 | Vizio VO370M 37 Class LCD HDTV
Vizio vo370m will power on then turns off log turns red then yellow why
sounds like the power board needs to be replaced. stand by the TV when you turn it on and listen real close near the top where the vents are at to see if it hums. also look in the vents to make sure the backlighting works. if not start with the power board. one other trick is to turn off the TV and unplug it. hold the power button in for 30 seconds or more the plug it back in and turn it on. If that does not work replace the power board
Jun 19, 2014 | Vizio VO370M LCD TV
When I turned on my vizio vo37om this morning, there was no picyture, screen is black. Sound is fine
Dim the lights in the room, turn on the set. Shine a bright flashlight on the screen, do you see a faint picture?
Feb 11, 2013 | Vizio VO370M LCD TV
Vizio VO370M LCD TV screen is mostly black with green/blue horizontal stripes at the to. How can I fix this?
Most likely you are looking at a defective LCD panel, but I would recommend getting a proper diagnosis.
Sep 07, 2012 | Vizio VO370M LCD TV
I need a vizio vo370M schematic diagram
has anyone found a place to buy a t2d diode 94 or t2d 94 diode for a vizio vo370m power supply board, placment d106
Dec 09, 2011 | Vizio VO370M LCD TV
I have a VO370M vizio hdtv that shows no screen, i changed all inputs, what will fix it
You probably have bad capacitors in your power supply. 2 1000@16v caps should probably take care of the issue. 195 general repair cost. Otherwise, if you look closely, you may have a bad inverter panel. 225-280 dollar fix.
Jun 16, 2011 | Vizio VO370M LCD TV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio VO370M LCD TV Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
