The fan is control from the electronic control so if it run for no reason then you need to replace the control panel. Id obvius that is the relay control but unfortunatly you need to replace the whole control.
Can you please let us have the model of your oven
We have here below the link with parts layout of your oven. The control panel Number 16 Oven control kit http://www.appliancepartspros.com/partse...
Part Number: AP3140310 made by GE
For a professional is about 20-30 minutes. However for the first time should take twice this time. As for the difficulty of the job, is 7 out of 10. Also this is a delicate job does not need to force anything hard since this will damage the new board. Also there some different multi wire plugs to remove and we advice to take some photos so you will have a reference in case you forget something. We would advice to go on and do it yourself only if have done something similar in the past if not leave it for someone else who knows about it, since there is a possibility of 30% to damage also the new control board is you connect something wrong or in the wrong way.
I have a GE Profile not a KitchenAid. Does the entire control panel still need to be replaced?
GE Profile mode JTP56WDW2WW
How long should it take to replace the oven control kit?
On a scale of 1 to 10, with replacing the fan behind the control panel a 2, how difficult is this job?
