Question about Amana ARGS7650SS Gas Kitchen Range
My Amana gas range spark modules won work, none of them four
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Oct 10, 2010
Why do all the burners spark in the off position non stop?
Try swapping the old module back in. If that doesn't work, check all your wiring - any one wire from the knobs to the module that contacts ground (the frame) may trigger the module to start sparking.
Jul 29, 2014 | Maytag MGR6772BDS Gemini Gas Kitchen Range
The spark on all four top burners stopped working. How do you I know if it is the igniter? And how do I replace it, if it is?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Sep 01, 2010 | Amana ACS3350 Gas Kitchen Range
I have an Amana ARGS7650ww. The igniters will not spark.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 20, 2010 | Microwave Ovens
None of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
Apr 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Gas range won't ignite. We had PGE and come over
This sounds like a failed burner igniter, also called a spark module. These are pretty easy to replace since the module itself is located at the back of the stove under an access panel. The price is around 40 to 60 dollars. Lately it seems that these newer stoves have weaker spark modules. I see dead modules on models less than 2 years old, where it used to be more like 5 or more years on the older ones.
Mar 24, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
On my Amana gas range 2 ignighters work an 2 don't. Does that help to narrow down the problem?
Hi.
Either the single ignitors are faulty, or the ignitor sparker module must be replaced.
The sparkers are tested energizing them.
The ignitor hub module is located under the cooktop panel.
Check also the wiring harness to spark module.
Here all parts and diagrams for your range.
Regards.
Mar 02, 2010 | Amana ARGS7650SS Gas Kitchen Range
Range top ignitor stopped working. electronic panel and oven work normally. Any idea what the problem is?
Hi, your spark module,for ignitor could be damage, sometimes they burnt out, or could be broken wires, or corrosion at electrical connection, (terminal) , normally it's spark module, that's faulty or burnt out. let mechanic check. or remove range plug from receptacle, and lift top of range, check all electrical wiring, check all connection for rust (corrosion) clean and retry range, if it didn't work, call mechanic to check spark module. good luck.
Aug 12, 2009 | Amana ACS3350AS Gas Kitchen Range
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
All of a sudden all four of my stove top burners do not lite electronically. I do not hear the clicking made by the electronic ignition. the gas comes on and can lite with a match. What happened?
either your spark module is out or you have a short at a burner switch.Go first and check the spark module for voltage out to the burners. Please Rate This !
Jun 09, 2008 | Amana Kitchen Ranges
Igniter
check your polarity at your outlet polatiry very important to theese re-ignition spark module, next with an old nail file)emory cloth clean the tops of the electrodes, after a whitle of continous sparking they tend to build up w/ carbon making it unable to detect flame thus continous spark
Feb 04, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
354 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
