Question about ViewSonic NextVision N2010 20 in. LCD Television
How do I unlock the input buttons on a viewsonic tv
HOW DO I AUTO SCAN CHANNELS ON VIEWSONIC VY2430
Do you mean the VT2430? Viewsonic doesn't list a VY2430.
For my Viewsonic TV, first make sure that your input is TV. (Press the Input button on the remote (upper left) or the TV (furthest right). Use the arrow keys or multiple presses of Input to change the current input.) Next press Menu. Use the up/down arrows to navigate to the TV menu (the icon looks like a TV). Press Enter. Set the type of incoming TV signal (Cable or Air or let the tv figure it out with Auto). Then go down to the line labeled AutoScan and press Enter. You may be prompted to begin the scan or to select the type of channels to scan. Press Enter again after making the selection.
Viewsonic has the manual for the VT2430 available on their site: http://www.viewsonic.com/products/vt2430.htm#tabbox_downloads . The direct link is http://www.viewsonic.com/assets/041/11502.pdf .
I hope this helps.
Sep 02, 2011 | ViewSonic NextVision HD12 HDTV DTV...
My ViewSonic N2230w 22 in has a menu locked and it cant change to a different input and im trying to unlock it but i cant i need to get it to unlock
Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
Nov 06, 2010 | ViewSonic N2230w 22 in. LCD TV
The menu button is locked on my view sonic tv how do i unlock it????
Depends on the model of TV. Some ViewSonics will unlock the menu if you Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
Sep 25, 2010 | ViewSonic N2230w 22 in. LCD TV
Need remote code for viewsonic rc00136p remote
hi! i have here a couple of codes for your Viewsonic tv, just try them, 1038, 1149, 1180, 1181, 1182, 1183, 1184, 1185, 1186, 1187, 1188, 1189, 1190, 1205, 1206, 1441, 1361, 1489, 1495, hope this helps!!!! goodluck!!!
Jun 09, 2010 | ViewSonic PRJ-RMC-002 Remote Control
N2635w 26 in. LCD Television: help me unlock my viewsonic...
try pressing and holding one of the "channel up" or "channel down" buttons for 5 seconds or more... While holding the button, you should see a progress bar that indicates "menu locking" or "menu unlocking". That should fix your problem...I found that out by accident on my TV.
May 10, 2010 | ViewSonic N2635w 26 in. LCD Television
I have a viewsonic VT2430 everytime i press a key on the remote and on the tv it says "button locked" how do i unlock it?
Hold down the volume buttons on the tv itself and it should display "unlocking buttons". Hold them down until it says ""unlocked".
Jan 27, 2010 | ViewSonic VT2430 LCD TV
I have a Viewsonic flat-screen tv, it displays "menu locked" ??
Try holding the VOL + and VOL - buttons on the TV (not on the remote) down together. You should see a "unlocking buttons" message on screen. This might work. However, I tried it repeatedly, as told to by the Viewsonic "service" rep, and it didn't work for me. Viewsonic is ****, and so is its "service"!
Jun 06, 2009 | ViewSonic N3251w 32 in. LCD HDTV
3735w Viewsonic Power lock problem
I had the same issue on my Viewsonic N3752w
The online guide, said I had to press VOL+ and Menu at the same time, but forgot to say
a) it's from the TV buttons NOT the remote!!!
b) you need to keep pressing these 2 until it stop saying "Power unlocking" but Unlocked.
Sep 14, 2008 | Televison & Video
Viewsonic n2751w
why does my 27 inch lcd monitor keep changing colors
Oct 18, 2007 | ViewSonic N2751W 27 in. LCD Television
ViewSonic NextVision N2010 20 in. LCD Television Logo
46 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
