Question about Kenwood Car Audio & Video
Keep blowing fuse for radio what is colr of constant wire
  • 625 Answers
The constant 12 volt wire is yellow. The accessory ( switched 12 volt wire) is red. The blue (power antenna) and blue/white (remote amp turn on) are also switched 12 volt wires. Make sure that they are not being grounded.
Posted on Oct 10, 2010
Vehicle information Center and radio fuses keep blowing at the same time. 96 jeep grand Cherokee limited. Help !
the fuse has only so many loads no actual fuse stated.by you.
there are more than one fuse related to a radio, besides the one marked RAD. so... why not tell the exact fuse.......????
we disconnect each to find the one that is shorted.
the fuse prevents the wire fire, so... do not up the amps.
ZJ , jeep it is. 96
fuses 3
FB 12 (fused dimmer to radio and other places
FB 15 main radio power,(run -acc)
PDC 17 dome lights and radio memory wire....
you need to know what fuse, then look in the FSM
and see all things wired to that fuse.
the starting page is
8w-47-2 (radio) (posted 100s of times)
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
does fuse hold if radio is disconnected?????
lets pretend fuse 12 blows
see page 8w-11-8 fuse 12, feed.
the next page covers fuse 15....
see?
you need to look at all feed wires to the fuse that blows
that includes options, and aftermarket hacks to car.
Nov 13, 2015 | Jeep Cars & Trucks
What would make the fuse under the seat keep blowing
There has to be a short in the line somewhere in order for the fuse to constantly blow. A wire has rubbed against some steel and is causing the fuse to blow. trace the fuse to the link....such as the lights or rear light and check the socket or wiring for a short.
Aug 03, 2014 | Polaris 2010 Sportsman 90
Why does my radio fuse keep blowing?
Because your radio is shorting out or you have a pinched wire somewhere in wire harness. Fastest way to find out is remove radio and disconnect all wires, then plug another fuse in. If it blows than its a wire problem, if it doesn't radio is bad.
Jul 07, 2014 | Chevrolet 2008 Chevrolet Uplander LT
Keeps blowing fuses not start
change your stereo wiring. you probably wired it to something wrong. you can either find a constant hot off of the fuse box. or find the radio fuse and wire it to that. the constant hot will allow you to listen to the radio with the ignition key off. beware of killing the battery though.
Jan 31, 2014 | Nissan Cars & Trucks
How can I keep fuel pump fuse from constantly blowing when trying to start up on a 2001 Pontiac grand prix gtp
Really !!!
You never replace a fuse when it blows
You get out your wiring diagrams & find out
what in the system would cause the fuse to
blow & make the correct repair
Nov 23, 2012 | Cars & Trucks
2005 Mustang GT radio defaults
You are loosing power to the keep alive memory circuit of the radio. I think you may have a defective ignition starter switch. Also there are two hot wires to the radio, one powers the radio, one holds memory and is called the Keep Alive Memory constant power wire. Here is the wiring colors, pull the radio and check the memory power supply wire.
Radio Constant (keep alive memory) 12V+ Wire: Light Green/Purple wire
Oct 31, 2012 | Ford Cars & Trucks
Radio, ignition coil, antitheft and climate control fuses keep blowing
try looking for a short in the wiring harness and do they run to the same fuse
Feb 16, 2012 | 2000 Ford Expedition
I think my alternator is bad would this also
NO. The alternator feeds the battery, not your cars systems. The car systems are powered by the battery and the battery is constantly charged by the alternator. If your radio doesn't have power, check the fuse first, then the hot lead to the radio with a test light do not ry to "spark" the wire to test for power as this will blow the fuse. A radio fuse is only a 5 or 10 amp fuse and is very easy to blow out.. If the radio is getting power then the radio has to be replaced
Mar 22, 2010 | 2000 Ford Escort
The radio and clock doesnt come on
check the fuses inside the car and replace the blow fuse the memory wire is just a constant 12 volt supply that runs to the clock and the radio! hope this helps
Jun 10, 2009 | 2001 Kia Sephia
No Power...Keep Blowing Fuses
you have a live going to ground meaning a live wire is touching another wire or touchin the caseing thus blowing your fuses
regards Doug
Feb 29, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Car Audio & Video Logo
55 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
