Question about Toshiba e-STUDIO 16 Printer
When i try to prine thru network printer Error: Illegal Attribute Data type am using vista32bit
How do I fix Service Engine Error 181.514. INK Sense BPD Prine Error.
Have you removed the plastic covering the ink jets on a new cartridge?
Feb 21, 2015 | Lexmark OfficeEdge Pro 5500T Multifunction...
PCL XL ERROR
Bad adobe command. Try printing as image in the print driver or using a PS driver.
Jul 21, 2014 | HP LaserJet 4050 Printer
Shows code b200
Hi Joseph,
Regarding your Pixma MX882 printer inquiry (Canon 225/226 ink cartridges) and B200 error message, most likely the built-in PRINTHEAD is reaching it's end-of-life and may need to be replaced with a new one. Typically, the average printhead only produces ~4000 to 5000 pages before it electrically fails.
For information on PRINTHEAD failures, please refer to our support page: http://inkjet411.com/?page_id=2934
However, let's run thru the full checklist to screen out additional variables:
Canon B200 Error, Troubleshooting:
Replace ink cartridges if they are empty:
At the risk of stating the obvious (frequently not so obvious in the heat of the moment), find out if the ink cartridges are empty. When in doubt, try a new Canon original ink cartridge to see if this corrects the error.
A data cable of print head is open:
Did you just replace an ink cartridge? Perhaps you shifted a data cable to the print head.
Replace PRINTHEAD if it is damaged. Refer to Canon.com for replacement part.
Turn off the printer for some time
In other troubleshooting tips we have advised any inkjet printer not seeing regular usage to run a test print page. If you are making heavy usage of a Canon inkjet printer, consider giving it a break. This will avoid saturating the printhead with heat, prolonging useful service life.
Update the printer driver:
If you have followed all this with no success, from the printer menu (not computer) push the buttons to get a demo or test page. If everything is ok when you do this, however you get the service error code B200 when you try to produce something productive, odds are good, the print driver the computer is using has gone south (corrupt). When printing on a network, a corrupt printer driver can spread like an unwanted virus. Depending on the network, a driver that has gone rogue may be seen as an updated driver, which network will 'helpfully spread' as an update.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
Canon 225/226 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=t1QDEDRZapY
To find an authorized ink center refill location near you (i.e. Costco, Frys, Micro Center, Best Buy, Sams or University bookstore location), using our premium quality & certified Canon inks, please visit: http://inkjet411.com/?page_id=3472
Please let us know if you have any questions regarding the technical information provided herein. For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Inkjet411 Team Representative
May 17, 2014 | Canon MX882 All-In-One InkJet Printer
I'm getting an error code Illegal attribute value on my hp 4050 printer
Nothing to worry about. It just means that you have printed a page or pages that all the trays do not have the correct paper size. Say your trays all have A4 papers and you printed a PDF document (US letter size) downloaded from America. Printer prints the page, then print another page with your error message just to tell you your pages do not match the papers. This is HP PCL6 code. A Postscript printer driver will just refuse to print if page size mismatches and keep the user wondering why.
To avoid the message, just make sure that your documents have the same page settings as papers in your printer trays.
Nov 26, 2013 | Computers & Internet
Out laser 2300 printer has ready, data and attention lights flashing and we cannot get anything to prine- we have tried cold reset and other suggestions and nothing seems to correct our problem- any...
All three lights flashing indicates a general failure. this is caused by either a bad connection, a bad formatter or a bad engine control board. Disconnect any cables you have attached to the printer and restart. If it starts fine then you may have a bad cable. If this is a networked printer, then it is quite possible that the network card has failed. You can try removing the network card if it has one and restarting. The JetDirect 615N card that shipped with this series of printers is notorious for failures.
Sep 06, 2011 | HP LaserJet 2300d Printer
The printer does not communicating with my computer it should say printing started, then prining finished but now it does not say anything
Solution What you will see
The printer will not respond despite the fact that you can confirm the printer communicates on the network.
You have also confirmed the following:
  • You can access the printer's web page.
  • The network printer object is present.
  • The printer is set as the default printer.
  • The printer is not paused.
  • The network printer port appears.
  • You have a green Wi-Fi light.
  • Your Firewall application has allowed or created exceptions for necessary Lexmark processes.
Suggested remedy
Verify that Lexmark services are running.
Procedure for Microsoft Operating Systems
Step Action 1 Click Start. 2 Click Run. 3 Type "services.msc". 4 Look for Lexmark services. (i.e. lx**_device) Click Illustration to Enlarge isdservices.jpg
Dec 20, 2010 | Lexmark X75 All-In-One InkJet Printer
Toshiba e-STUDIO 16 Printer Logo
261 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
