Question about Kenmore 24972 Top Load Washer
Trying to remove the agitator from a kenmore top loader. took off agitator cap but there is no nut down inside. i see metal but nut drivers and sockets won't fit, down opening. should i just pull up on the agitator from the bottom?
  • 15,935 Answers
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Posted on Oct 10, 2010
Testimonial: "Thanks. That's all I needed to know about the recessed square plastic nut. Removed nut and the agitator dog assembly came up and out."
    Scholar:
  • 116 Answers
Some models have a round filter screen that must be removed from the center to expose the nut...
Posted on Nov 13, 2010
Agitation not right
Many Whirlpool top loaders with big spiral agitators need slightly deeper notches sliced into the 4 rubber ratchet teeth grippers to get a better grip. Of course then you could just buy some new ones. The top just pops off your agitator and you reach down inside to get the cap out, then a long extension and a 7/16 socket to remove the nut. Good time to clean all that stuff in there.
Mar 08, 2014 | Whirlpool Washing Machines
How to remove agitator separate two parts
Removing the agitator on a Kenmore top loader involves the following steps:
1. Remove the agitator center cap or softener dispenser by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16 inch hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8 inch to ½ inch ratchet adapter to remove.
4. Remove the lower portion of the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make any repairs much easier.
5. Place your hand over the top of the agitator and separate the upper portion (auger) of the agitator from the lower portion and turn the top half over in your hand. The agitator cam assembly will come out in your hand.
6. With the cam assembly in your hand, pay careful attention to how everything is assembled. The cam asembly and associated parts usually wear with age and will cause the agitator to slip. If any of the cam assmebly parts appear worn, now is a good time to replace them. The entire assembly is usually sold as a kit for $20 or less.
7. When reassembling the agitator, carefully align and reinsert the upper portion of the agitator to the lower portion. Make sure the two pieces align correctly. If equipped with an inner cap, make sure it seats and seals properly. This provides an air gap to prevent water from rising in the agitator shaft and getting inside the transmission.
8. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
If any replacement parts are required, they can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
The agitator cam assembly should be listed under the agitator parts listing. If you have questions, please post back and let me know. I hope you find this information helpful.
Feb 22, 2011 | Kenmore 22622 Top Load Washer
I take the fabric sofener top of and then the cap
I'm assuming that you have a basic Kenmore / Sears top loader with a two piece agitator. On some of them (and I'm assuming yours) the nut is a plastic part that takes a 1/2" drive socket extension. You'll have to hold the bottom agitator to keep it from moving and give the wrench some (but not a lot of force) to loosen it. If the washer has never been taken apart, there may be some build up around the bottom of the nut.
Oct 31, 2009 | Kenmore Washing Machines
How to remove the agitator from a top loading kenmore elite washing maching
The agitator on a Kenmore top loader can easily be removed by performing the following steps:
1. Remove the agitator center cap (or fabric softener dispener) by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make reassembly much easier.
Is there a reason you are removing the agitator? If you have questions, or require additional assistance, please let me know. I hope this helps you.
Jul 09, 2009 | Washing Machines
How do you remove the agiatator on a kenmore elite top loading washer
Jul 09, 2009 | Dryers
Agitator barely turns, especially with a full load. It's a Roper Washer top loader.
Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
May 04, 2009 | Washing Machines
The tub jumps around in the spin cycle of Kenmore 90 washer.
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2009 | Kenmore Washing Machines
Agitator will not spin on kenmore model 11022872100
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
Jan 25, 2009 | Kenmore Washing Machines
Kenmore-80series washer -the agitator needs to be replaced.
remove the agitator cap,,remove the plastic seal under just pull straght up with your hand,,inside agitator theres a nut,,remove thi 1/2 inch nut with ractet and pull agitator straight up
Dec 23, 2008 | Kenmore 24032\24036 Top Load Washer
Softener
that cap has a rubber o-ring at the edge. it covers the nut so that no liquid would be spilling on the metal nut . just slowly press the cap downwards the inside of the agitator and press it firmly then put back the softener container on top.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24972 Top Load Washer Logo
169 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
