Question about Lutron Maestro 600-Watt Multi-location Dimmer Terracotta #MSC-600M-TC
LHave a Lutron DV 600P single pole incandescent dimmer installed and the while the slide mechanism works and lights come on the switch won't stay on.... therefore no light unless one presses the light fixture continuously. What to do?
The dimmer is worn out
Wall switches and dimmers don't come apart for repairs >> nobody sells parts >> and the wiring didn't suddenly go bad.
Posted on Oct 11, 2010
Lutron Dimmer: 'IN' does not always equal "ON"
These are probably three-way switches being used as two-way. If so, then the switches will have three terminals, but only use two. Just switch one of your wires to the other terminal. If the light will not light, that was the wrong wire. Don't mess with it without turning off the breaker! Good luck.
Feb 25, 2013 | Lutron LG-600P Lumea Single-pole 600 Watts...
Lutron Dimmer switch, single pole, will not dim
We are truly sorry for your inconvenience and want to help. Please call our Technical Support line at 1-888-523-9466 and we'll be happy to discuss the issues with you.
Craig, Lutron Technical Support Leader
Nov 22, 2012 | Lutron #D-600PH-DK 600W SP Push Rotating...
Try to add a dimmer but we have 2 blacks and 1 red wire. Product has 2 black and 1 green. How to connect?
Usually this is indicative that you have a 3-way lighting circuit, but only a single-pole dimmer. For most lighting circuits, the red wire and one of the black wires are supposed to be run over to a second light switch. You need dimmer rated as a "3-way" in order for that to work. If you get stuck, I would call the manufacturer's tech support number at 1-800-523-9466. They're available 24/7 and it will not cost you anything.
Jul 23, 2011 | Lutron LG-600P Lumea Single-pole 600 Watts...
How connect 3 way dimmer.I can connet two 3 way dimmers
No, you can only use one dimmer, the other switch has to be a regular three-way switch.
Feb 02, 2011 | Lutron GL-1000 Glyder Single-pole 1000...
I have two black wires in box attached to regular light switch & want to know if I can install a Skylark S-603PG single pole dimmer switch which has one black , one red&white, red and green wires
This is single-pole -or- 3-way dimmer
Manual shows on following link:
http://www.lutron.com/TechnicalDocumentLibrary/0301107A.pdf
1) Manual says: The red/white wire is not used in a single-pole application. Twist a wire
nut over this wire for a single-pole application.
2) Green wire connects to bare ground wire. Or bare ground to bare ground.
3) Connect dimmer-red and dimmer-black to either insulated wire that came off of old switch
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
We are always less expensive than a service call.
Jan 14, 2011 | Lutron S-603PG Skylark Single Pole/3-Way...
Problem with 1000 w sliding dimmer switch; lights stay dim regardless of slider position but eventually brighten
I think you need a provide a little more information in order for there to be a possible solution. I'm particular confused by your use of the term "eventually" - these are analog dimmers, there are no "smarts" involved with this products, so I don't get how it would magically turn itself on to a higher brightness. Regardless, you will be able to get a much quicker answer by just calling Lutron directly. Their tech support number is 1-800-523-9466, they're available 24/7, and it won't cost you anything. They can help you diagnose whether its something related to installation or whether the product has simply hit the end of its life, and they can probably assist you with gettting a replacement as well.
Jan 08, 2011 | Lutron GL-1000 Glyder Single-pole 1000...
Ok i installed the Maestro IR on a switch that runs a celing fan with a light on it. i turned the power back on in the room and the light was flickering and the fan was unresponsive. please help!!
Lutron Maestro IR shows several model numbers:
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro+IR%C2%AE+dimmer
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen.
Installation manual:
http://www.lutron.com/TechnicalDocumentLibrary/030864b.pdf
If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan'
It appears this dimmer is for incandescent and Halogen lights.
Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service.
Expert will walk you through the problem for a price.
Dec 25, 2010 | Maestro Lutron MIR-600 IR Satin Color...
The internal plastic rocker slide has broken. Don't care to spend $30 for a new switch. Just need the plastic rocker slide piece. Where can I get this?
Wall devices do not have replacement parts.
I was just at Lowes buying GFCI receptacles and noticed they have ordinary switches for less than $2.
The Lutron designer devices are more expensive. The local box store may have a reasonable alternative.
When replacing a dimmer or timer, check a couple things. Not every dimmer works for all types of lighting. Some devices are for incandescent only. Some devices are rated for 500Watts and others are rated for 1000Watts. You may have a 1000W dimmer, and they are more expensive as you know.
Oct 22, 2010 | Maestro Lutron MA-600G Single Pole/Multi...
Lutron Maestro 600-Watt Multi-location Dimmer Terracotta #MSC-600M-TC Logo
217 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
berniekruege
Level 1 Expert
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
