Question about Refrigerators
LG refrigerator works for a few seconds then trips off unplug cord and replug into outlet refrigerator will restart and run for a few seconds then trip off. Model lrsc2641st side by side, could it be the run capacitor bad.
  • wbk2p Oct 10, 2010
    I checked the overload klixon cut out at the compressor it seemed to be fine with a meter also checked compressor winding and got ohm readings around 6.5 ohms, I dont understand how it could overheat OL because i let it set off unplugged for ten minutes and it will only run for about 30 seconds after plugging it in to the wall outlet, also right after pluged in the ice water temp lcd panel will slightly flicker when the compressor cut on then it will trip off. Model #LRSC2641ST
    Thanks,
  • Refrigerators Master
  • 1,711 Answers
The problem is with compressor. The overload protector cut it off to protect it from burn up.
The two most possible faults are.
First the lost of refrigerant gas can make compressor overheat so the overload will cut it off. You need to check freon gas and charge if needed.
Second the compresor winding have been burned and thats cause the overload cutout. You will need a new compressor. You can test withun ohm meter the compressor windings.
Posted on Oct 10, 2010
  • espressonist
    espressonist Oct 10, 2010
    From the data you have in your reply the other only thing that can cut the compressor in so short time without any reason is relay on the control board. However as you may already know you cannot fix the control panel therefore you will need a new control board
My refrigerator lg LFC20760SW. It just went off by itself. It won't power on at all what can I do.
Check to see if breaker is tripped .Unplugged fridge and check to see if there is power to outlet .If there is power to the outlet then follow the fridge power cord and check that connection .Maybe a burnt wire
Jun 03, 2017 | LG Refrigerators
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
Few months old WM3987HW won't turn on - seems dead, unplugging and replugging won't work; outlet has power
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Aug 07, 2011 | LG WM3987HW Front Load Washer / Dryer
We are cleaning refrigerator and want to turn off the buzzer. Buzzer will not turn off. Help Please!
Unplug the refrigerator unit from wall outlet and let stand for 35 seconds - then replug
Jan 01, 2011 | LG LFX25960ST Stainless Steel French Door...
Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Apr 19, 2010 | Dometic RM2652 Refrigerator
Ge side by side refrigerator trips GFI
Try an extension cord to get it off the GFI outlet .
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZER WORKS...FRIDGE DOESN'T
Hi,...
In that case you need to check this
  • Make sure the refrigerator is plugged in securely
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for current
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
Good luck !!!
Regards
PCmania
Jul 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
