Question about Sony Cyber-shot DSC-S700 Digital Camera
Power on n off
When I try to turn the power on, it shuts off immediately. "Cyber-shot" appears in the window, then it beeps twice and turns off. I've tried new batteries i put new batteries in but it beeps once shows da cyber-shot screen and then it turns off but da lens stays out.
  • 2 more comments
  • Anonymous Jun 25, 2008
    same prob
  • Anonymous Nov 12, 2008
    me too..did you get it fixed?
  • ryanator dud Dec 04, 2008
    myn just goes on and shows the green light and on the screen cybershot and then shuts down again... wat must i do can u help please...
  • adjoba Dec 27, 2008
    Same problem here but none of the posted solutions worked. Anyone else experienced this problem and solved without going to the sevice centre?
I also had this problem with my DSC-S730. Take the batteries out and hold the power button for 10 seconds. Get new name brand alkaline batteries. Warm them in your hands and insert them properly and close the battery door. Then hold the camera upside down so the batteries make good contact and press the review (>) button.
Posted on Oct 13, 2008
    Problem Solver:
I had this problem with my DSC-S730. Try re-setting the camera. All you do is take the batteries out, then press the power button and hold it and count to 10. Then put the batteries back in. That worked for me!
Posted on Jun 30, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
Posted on Jun 24, 2008
Camera turns on and off
when i power the camera i only get the cyber shot logo and the camera goes off and i get lines on the screen.what could be the problem?
Sep 20, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
This problem is related to optical zoom motor,The part detail is given below:
Part No. Description
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Thanks for using fixya.
Jul 29, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Message turn power on and off... Lens stuck as well.
u may as well kill urself. its broken. go get it checked out. i took apart my camera and tried to fix it myself... i shocked the **** out of my hand. best buy or something
May 25, 2009 | Sony Cyber-Shot DSC-P31 Digital Camera
Lens wont open
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
If you have a memory card in the camera, take it out before turning the camera on
Aug 28, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
E:91:01 flashing and beeping few secounds after camera is turned on
make sure its charged or check to see if anything has happened to it.
Jun 19, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Lens stuck open
I have to agree with one of the comments previously posted. I too had a Sony DCS-S700 and the lens was stuck open. Whenever I turned the camera on, the Sony Cybershot logo appeared and dissappeared, turning the camera off. I noticed the lens was crooked, so I moved it in the center direction and the camera worked again.
Mar 06, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Power on n off
I had the same problem, corrected it by cleaning the battery contacts inside the camera.
Dec 21, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Camera won't turn on...
I got this from the Sony website. I haven't tried it yet. I also have an email in to them.
Follow this procedure to troubleshoot if the power will not turn on.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure you are using fresh or fully charged batteries. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries.
  4. On the camera, move the mode switch to the Playback/Edit mode and attempt to turn on the camera.
  5. If the issue is not resolved, try connecting the AC power adapter (if applicable) to the camera and a working electrical outlet.
  6. Attempt to turn on the camera.
NOTES:
  • Not all cameras are provided with an AC power adapter.
  • If the issue is still not resolved or the camera operates in one mode but not the other, then service will be required.
Aug 29, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
270 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
