Question about Haier ESD210 / ESD211 Built-in Dishwasher
This thing has never drained properly. You have to hit the cancel/drain button a few times for it to finally drain. I don't think it drains completely after wash and before rinse because everything comes out covered in particles that weren't there going in. We've checked the hose, and for stuck food with no luck. There aren't many dishwasher repairmen in my area and I'm at the point it's just a giant drying rack while I hand wash. Any advice would be welcome!
  • 62 Answers
If its never drained properly, then perhaps it was installed incorrectly. Check that the drain hose goes up and over the machine before connecting to the homes drain pipe.
Posted on Jun 16, 2017
2 Suggested Answers
  • 2976 Answers
SOURCE: Brand new dishwasher will not drain at end of cycle.
Check your manual. Some dishwashers actually do leave water in them after the final drain cycle. It has to do with the type of seals they use. Some will leak the very first time they are used but not after that. The seals in these types must remain wet. If this isn''t the issue, wait about 5 minutes fir the timer to finish. Sometimes there is quite a lag at the last cycle. If all else fails, call the customer service number in the manual.
Posted on Feb 02, 2009
Troubleshoot my kenmore dishwasher won't drain
Check that the drain hose isn't kinked or blocked. Check that the pump inlet in the bottom of the dishwasher isn't full of gunk.
Oct 13, 2014 | Kenmore Dishwashers
I've got a Kenmore 630.1630 dishwasher that does not finish it's cycle. It remains in the final rinse/drain cycle with 0:01 showing for hours. I have used the cancel drain (china & rinse buttons) to end...
if it uses an electric heating coil to boost temp- that may have failed. they don,t last forever! if it is pretty old, and fixing it costs a bunch- may be time to add a new member to your kitchen appliances! the latest consumer reports has some 'best buys' listed. (no- i don't work for cr!). good luck!
Nov 04, 2013 | Dishwashers
I have a 6mth old Maytag Quiet Partner that will not drain. I took the hose off the drain pipe and hit the Cancel/Drain button and put the hose into a bucket-worked fine. I then re attached the hose to the...
Seeing where it will work when disconnected from drain, i would be looking at the house drain as the problema nd not the dishwasher. You can check these things.
1) a clogged pipe under sink that it connects to
2)do you hava airgap,its a piece that goes on the sink and hasa chrome cover about 2-3 inches tall,if ya have one of those(not all drains do) reomve cap by pulling off and depending on brand of air gap unscrew inner cap or push in the 2 tabs and pull out inner piece to check for a blockage
3)if you dont have airgap is the drin hose under the sink always slooping down? at on point the drain hose should be higher that the level of the peice on the drain it attaches too,with corrogated drain hose its easy to pull it up and attach it under sink so at one point the hose is higher that the drain(disposer) nozzle
Good luck, i hope this helps
Gene
Aug 04, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishwasher is not draining unless I hit the cancel drain buttons. I also noticed that when time gets down to 1 minute it stays there and keeps running
Most likely it is not completely level. This will stop the cycle every time. The drain/cancel just overrides the sensor, but you need to level it up completely, this should solve the problem
Dec 23, 2010 | Dishwashers
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
Dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Sep 13, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Haier ESD210 / ESD211 Built-in Dishwasher Logo
42 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Tom Chichester
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
