Question about Amana NED7200TW Electric Dryer
Amana dryer NED7200TW quit heating, it appears everything else is working
  • Amana Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
Amana NED7200TW dryer. Has heat, tumbles, clothes don't dry. Vents have been gone through and cleaned. This happens in the sensor dry and time dry modes. Any thoughts? Thanks!
Just a question. Does your blower work. If your blower does not work it won't dry. Check blower belt. Mine broke and had no air blowing. Just a thought.
Oct 21, 2016 | Amana NED7200TW Electric Dryer
I have the part to replace broken heat element on Amana 6100; where are the screws holding it in place?
Replace Amana NED7200TW Heating Element Heater Coil ...
? 10:43
https://www.youtube.com/watch?v=5469BpQpJZQ
Dec 14, 2014 - Uploaded by Mike Griswold
How to replace the heating element on your Amana NED7200TW Dryer. ... Pulled apart my dryer and ...
Oct 31, 2015 | Amana Kitchen Ranges
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
My amana dryer model ned7200tw runs good but no heat
check element, termo fuse (top side of element casing) and electric box as it can run with one side (117 Volts) good and one bad..
Jan 05, 2015 | Amana NED7200TW Electric Dryer
Everything works but no hot air. Thermostats, thermistors, and heater ohm out correctly per the owners manual
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 08, 2011 | Amana NED7200TW Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
My Amana NED7200TW runs but will not heat up. I don't get any error codes. Help.
heatman101;
May 10, 2011 | Amana NED7200TW Electric Dryer
My dryer is an Amana #NED7200TW and I got a code HE on the display panel and there is no heat coming out. We tested the heating element protectors and they were fine. What could this mean? It is not in the...
HE shows up because there is no heat . Check the fuses in the panel and the heater itself. Also could be the sensor is not working to tell the control to turn the heater on.
Oct 29, 2010 | Amana NED7200TW Electric Dryer
I have an Amana NED7200TW Electric Dryer that was working fine before I moved it from my brothers house to mine. Now the heating element is not heating up. Everything else is working fine. Any suggestions
You probably busted the element during the move and this not a serious problem. These parts are fragile and easy to repair. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.Call us from 7 AM until 9 PM CST. We hope to help you repair your dryer. Thanks, Ella
Nov 17, 2009 | Amana NED7200TW Electric Dryer
Amana NED7200TW Electric Dryer Logo
827 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
