Question about RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA CUTTER 1-5130- 1
Doesnt turn on , i replaced the fuse but it keeps blowing off
  • ms123metalar Oct 11, 2010
    my thermal dynamics cutmaster 50, keeps blowing the fuse and wont turn on , yet there is a red glowing light, also where would be the first area to start looking for shorts, or sparks, or brown spots
  • 12,061 Answers
You most likely need a Higher Power Mains supply feed, and or breaker/fuse?
Usually one needs at least a 20 or 30 AMP fuse.. or better yet a 35 - 60 Amps when on Single/Three Phase. or if not more in some bigger cutters, cases. So are you sure your power system can take a unit such as this?
Also sometimes it is necessary to install Slow Blow, Motor Breakers and Fuses. These allow the large Inrush, currents, and do not blow or trip, initially... yet still providing full protection.
Normal fuses cannot cope with the inrush current, and subsequently trip or blow, at turn on, as machines such as this and motors all draw many times the rated current at startup, but, then it drops down to an acceptable level, again after the initial inrush...
Now if it is NOT the supply/fuses/breaker, then the ONLY other thing that can cause this, is a short circuit between Phase, and Neutral/Earth. Either in the mains cord, or in the unit itself. This shouldn't be hard to find with a meter. Simply isolate the cause, and repair or replace the parts as required, often these units fail in the Power Supply.
Posted on Oct 12, 2010
  • RTO Master
  • 43,501 Answers
To find out why the fuse keeps cutting off you will need to open that up and trace down the problem with an OHM meter...
You may find a black spot where it is shorting or arcing, but if not then the circuits will have to be traced and eliminated one by one till you find the source of the problem...
It could be anything from bad wire or connection to a bad transformer..
heatman101
Posted on Oct 10, 2010
Why do i keep blowing the p e d fuse under the hood
What is the PED fuse, and what does it control?
May 18, 2015 | Cars & Trucks
Odometer fuse keeps blowing when starting
Try a slow blow fuse? I think thats what they are called.
Mar 14, 2014 | 1996 Chevrolet Blazer
Fuel pump fuse keeps blowing
unplug wiring from pump, replace fuse if it doesnt blow then it is in the pump. If it does then check wiring for short.
Jan 10, 2014 | Mercury Cars & Trucks
1997 saturn sw2 station wagon horn doesnt work keeps blowing fuses
Ever consider disconnecting the horn,
& then see if a fuse blows
Maybe the horn needs to be replaced
Feb 18, 2013 | Cars & Trucks
Radio fuse keeps blowing on 99 ford escort zx2
I would say there is a short somewhere. You can get a resetable fuse.
May 31, 2017 | 1999 Ford Escort
I have a fuse that keeps blowing and the white letters are gone so i dont know what it goes to
you have some componet that has melted down contacts (it's hotwire is grounded) so every-time u turn on the key power is fed to direct short and the fuse blows.So look around at things that dont work.after fuse blows does motor still operate,keep it running and find out what doesnt work then check that component for melted,grounded wires...
Dec 27, 2011 | Cars & Trucks
All the lights work except the dash lights. The 5 amp fuses keep blowing and if I put a 15 amp it doesnt blow but no dash lights
DASH HAS A SHORT CIRCUIT.DASH NEED REPLACING BUT CHECK FOR SHORTS IN THE WIRES TO DASH.DONT PUT A LARGER AMP FUSE IN A CIRCUIT TO KEEP FROM BLOWING FUSE BECAUSE IF FUSE DONT BLOW WIRES GET HOT IN THE CIRCUIT THAT HAS A SHORT IN IT AND CAUSE A CAR FIRE.
Nov 04, 2010 | 1992 Ford Thunderbird
ECMB fuse keeps blowing on a 88 S15 pickup. I have replaced the fuel pump & the fuse block but my fuel pump still doesn't work
Un plug the Computer to see if the fuse doesnt blow now. You may have a short in the PCM or the harness.
Aug 31, 2009 | 1988 Chevrolet S-10
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA CUTTER 1-5130- 1 Logo
175 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
