When pushing the on switch it goes on for a few seconds then cuts off
  • 15,935 Answers
This is likely a power supply issue - best left for a professional to repair.
Thanks!!
Posted on Oct 10, 2010
My dryer cuts on and then off I have by passed the thermal cutoff fuse and the door switch it will turn on when I plug it back in and run a few seconds and then cut off please help
does it run as long as you keep the start switch pushed then stop when you let go of button if so bad centrifugal switch in drive motor
Feb 20, 2015 | Dryers
My AX 562 Amp keeps cutting out
Check your cables and your inputs. Input might be loose or wearing out and need to be replaced. Same thing goes for cables as well.
Mar 14, 2014 | Audio Players & Recorders
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
Water heater doesn't keep running
Sounds like youo have a problematic gas valve. But I would get a gasfitter to replace it. Not for the amatuer.
Nov 20, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Machine filled with water and won't continue the cycle. pushed on the lid and worked for a few seconds and now won't work at all
The lid has a safety cut out switch which prevents the unit from operating while the lid is in the open position. You need to locate this switch which is on the hinge side. Remove the control panel covers. The switch may just be loose or have a bad connection.
Nov 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Lawnmower doesn't fire or start at all
see if plug has fire, could be bad plug ,bad coil,or shear pin has sheared
Aug 13, 2009 | Garden
Push power button on, stays for few seconds, shuts down
The most comon cause is a faulty mode switch.
Mar 16, 2009 | Televison & Video
Motor goes on/off every few second.
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Thanks.
Dec 28, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
