Question about Refrigerators
It started out with ice building up on bottom of freezer and water leaking out of bottom of fridge. Now fridge side is not working . Freezer side still works and when you open door you can still hear a fan running somewhere . The big fan in the back under the freezer side and next to the compressor however is not. We are broke right now and not sure what to do. I need to fix myself if possible.
  • 4 more comments
  • tracylynn64 Oct 10, 2010
    there seems to be power coming from compressor. Freezer seems to be thawing out now though. it feels cold but ice is thawing out. I have a box fan blowing at compressor and at fan that isnt working. is this making freezer not work right . could it be something that caused fan to go out? fan is not locked up. it will move easily but will not turn onif fan is cooling off the compressor wouldnt fridge kick back on? or does it need to blow directly in to the spot that it is facing in to?
  • tracylynn64 Oct 11, 2010
    so just that fan not working can cause fridge not to work? hat do you think was causing the leaking water on the fridge side? since that side is not working the water stopped leaking and there is no ice in bottom of freezer. I need to stop water too.
    I checked for power and it is getting power through cord coming from compressor..Can a fan cause fridge not to work? Where was water coming from? It was coming out on fridge side. Since fridge is not working the water has stopped and there is no ice in bottom of freezer. do you think something caused the fan to go out and it will happen again or will this solve my problem? How do I keep it from leaking again? It is ruining floor
    compressor is warm and box fan is keeping it from getting too hot. Doesnt compressor control freezer and fridge? Freezer is still freezing.If compressor is shot it would not be heating up would it?
    I need compressor fan motor kit right?
    Heatman101 was very helpful and responded in a timely manner. A+++
  • Refrigerators Master
  • 43,501 Answers
Check for power at that fan....if there is power then the motor is bad...this often happens...it can be easily replaced.
If there is no power then the control board is probably bad..... that costs more but is still easily replaceable...
Here is a tip about how to go about finding and buying the parts online.
Howto Buy Appliance Parts Online
heatman101
Posted on Oct 10, 2010
  • 1 more comment
  • D. Floyd Kolb
    D. Floyd Kolb Oct 11, 2010
    You will still need to get the ice thawed off of the coils in the freezer before anything will work right...to do that turn off the refrigerator and take a hair dryer to the ice till it is gone...
    Then you can try the box fan on the compressor, but that may not be air on the coils underneath directly enough to actually keep the fridge working...
    It sounds like that fan motor went bad and that you will need to replace it...a tech could soon test for power and tell you for sure...
    Keep trying... you'll get there...
    heatman101
  • D. Floyd Kolb
    The water is coming from the ice melting... but it sounds like you may have multiple issues...the compressor may have got hot and now won't work either...
    It is very hard from here to be able to tell exactly what all is going on there...
  • D. Floyd Kolb
    Yes, compressor could be bad and still be getting warm to hot....also could be low on freon which would make it ice up and maybe cool the freezer but not the fridge.... and yes the same compressor does both...
    They are a number of things that could be happening there...
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
GE Fridge with ice maker. Water is slowly leaking
drain is clogh at the bottom of the freezer
Mar 29, 2009 | Refrigerators
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Water leak
probably the defrost drain blocked. remove back panel from inside freezer and melt ice off with hairdryer and follow up with hot water till water flows away freely.
you may find all the pipework iced up and if so you have a problem with defrost system.
an alternative way is to switch off for 24 hours and leave doors open
Aug 23, 2008 | Freezers
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Cannot open the bottom freezer door anymore; it seems stuck
sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
May 06, 2007 | Sub-Zero 611 / O Bottom Freezer...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
