Question about GE (PSS26MSRSS) Side by Side Refrigerator
The auger dosn't turn when front pannel is activated. Could it be a Fuse
    Sergeant:
    Champion:
  • 351 Answers
Hi more thin likely the motor has frozen up wont turn ge makes a kit to stop that jim
Posted on Oct 11, 2010
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
Jan 25, 2014 | Simplicity I924E 2-Stage Snowblower...
Auger has no torque
Assume it is 2 stage ie: front auger and impeller. If the impeller turns and the front auger does not then it is probably the shear bolts have broken. The shear bolts are soft metal and are designed to break should the front auger hit something hard. There may be a small tool box on top just right of the chute, there shud be bolts there. DO NOT under any circumstances replace these with regular bolts as major damage to the engine could occur. Hope this helps
Jan 23, 2014 | Craftsman Garden
Ice dispensor in the door will not dispense ice
do you here anything at all happening when you hit the switch... if you not then most likely got a bad door switch or handle is broke at the area where it makes contact with the door micro switch...if you are hearing noise when activating the door switch you are good at the door... with the door opened hold down the actually freezer door switch and look in your ice maker while someone activates the ice dispenser switch. makes sure the augur motor is turning and if it is then make sure it is turning the ice bucket auger screw fairly simple process to go through... the operation is as follows the dispenser handle makes contact with a microswitch in the door and sends power to the auger motor telling it to turn.. once the auger motor starts to turn then it makes contact with the screw in the bucket and turns the screw in bucket forcing ice to front of dispenser and the dispenser has a flap that works both off of power sometimes or just by force of hand others... make sure it is opening and chute down and out door is opened. hope this helps good luck
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The dispenser auger turns but is not dispensing any ice. The auger turns freely and sends ice toward the front of the bin but nothing comes out. What can be done to fix it? Does the blade toward the front...
You have a cube of ice jammed between the rings of the auger...this stops anymore ice from moving out of the auger...
remove ALL of the ice from the tray and the auger and then let it refill... then it will work again...
heatman101
Aug 05, 2010 | Frigidaire FRS26ZSG
Fan blower fuse location on a ford f150 year 2000
FUSE #105 40A** Climate Control Front Blower, THIS FUSE IS LOCATED IN THE UNDERHOOD POWER DISTRIBUTIOPN BOX
Oct 14, 2009 | 2000 Ford F150 Flareside SuperCab
Ai conditioner runs hot on cool setting
ac fan fuse should be in engine comprtment in a labled box near firewall passenger side
May 31, 2009 | 2003 Honda Odyssey
The icemaker makes ice, but it won't dispense.
rmielsen and PhyllisForbe,  Your refrigerator has an auger motor that causes the ice to be dispensed when you press the ice selector on the front of the refrigerator.  You could have several possible problems that will gives you the same result.  The auger motor could be at fault. The ICE selector part of the  control panel of the front of the refrig could be at fault.  To isolate to auger or control... do the following.  Remove the ice bucket or auger assembly from the freezer. Reach into the freezer compartment where the auger assembly normally would be.  You should be able to see a "horse shoe shaped metal drive assembly" that would mesh with the auger assembly (ice bucket) to turn the cork screw shaped auger. Try and turn the auger drive assembly in rear of freezer to determine if motor armature is free.  The is somewhat difficult to do because the auger motor is high torque, slow rpm motor, but it should turn if it is good. Sometimes the auger motor will become stuck due to a water leak, inactivity, high humidity during a defrost cycle, etc.  The more possible suspect is the ICE selector assembly on the front of the refrigerator.  If any function on the refrig fountain dispenser control panel goes bad...then the ice/water control assembly will need to be replaced.  Hopes this helps you!  HandyHenry
Jan 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
Jan 16, 2009 | Napoleon Auburn Pellet Stove Heater
FRIGIDAIRE SIDE BY SIDE ICE DISPENSER
Have same or similar problem. MY problem turns out to be that the Auger turns fine, but there is a little metal blade that attaches to the end of the auger and transfers the spin action into this auger "hopper" (for lack of a better term) which actually accepts the ice that has been moved from the back of the ice bucket by the metal auger and then dispenses the ice into the hopper which falls into the glass. the issue is one of crappy design. It turns out that this little blade has a rectangular opening in the middle that the rectangular end of the auger fits into. If this rectangle opening gets stripped (as mine has done, and ALL are likely to do) then the auger spins, the ice is moved forward but none are picked up by the hopper, and none (or very few) fall into the glass.
Everyone should check to see if this is the case. If so you may need to order a new blade, or a new auger, or a new refrigerator.
Good Luck!
Aug 10, 2007 | Frigidaire FSC23F7D Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
